[GRASS-dev] what does zoom= do?
On Jan 27, 2008, at 9:07 PM, grass-dev-request@lists.osgeo.org wrote:
Now what does 'g.region align=' do?
Hamish
This one I can answer. When you zoom, g.region has to maintain an integer number of rows and columns. Without -a, it will find the nearest integer for the rows and columns given the extents and resolution specified. Then it will slightly adjust the resolution so that the specified extents are exactly divisible by the calculated integer number or rows and columns.
With -a, g.region will slightly adjust the extents (instead of the resolution) to come up with an integer number or rows and columns as close as possible to the selected extents while exactly maintaining the specified resolution.
Try it by running g.region -ugp after setting a region to specified extents and resolution with and without -a. Without -a, the resolution will differ slightly from those specified, but the extents will exactly match those specified. With -a, the resolution will exactly match and the extents will differ slightly.
However, -a is ignored if the resolution is not specified. I asked that in circumstances where resolution is not specified and -a is used, g.region align to the current resolution, whatever it is.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
It does a bit more than that. It aligns to a grid which is aligned to
the origin of the coordinate system.
IOW, even if the region dimensions are an exact multiple of the
resolution, the bounds may still be shifted.
E.g. if you have an X/Y coordinate system with res=10 and bounds:
  e=15, w=25, s=15, n=25
the -a switch will cause the extents to be changed to:
  e=10, w=30, s=10, n=30
so that they align to a 10-unit grid which is aligned to the origin.
