[GRASS-dev] what happened to r.out.arc?
r.out.arc has disappeared from GRASS 7 and it is not at all clear what other module will output ESRI ASCII format. We need that to feed into NetLogo but it is also a pseudo-standard.
Any suggestions?
Michael
C. Michael Barton
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
http://www.public.asu.edu/~cmbarton
On Mon, Mar 9, 2015 at 5:47 PM, Michael Barton <Michael.Barton@asu.edu>
r.out.gdal does not do that?
Anna
Any suggestions?
Michael
            ______________________________
C. Michael Barton
USA
grass-dev mailing list
grass-dev@lists.osgeo.org
On Mon, Mar 9, 2015 at 10:47 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Please see
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Replacedandremovedmodules
-> r.out.arc: use r.out.gdal
So AAIGrid is the newish name for ESRI in gdal I guess. In tests today, it has the same problem as before.
The null values need to be specified as -9999. This is not a big problem. Just a little annoyance.
Sometimes it exports different headers that are not compatible with NetLogo raster ingest. Perhaps this is the only program that has a problem but maybe not.
Sometimes it exports a header with a single “cellsize” line (which is what r.out.arc always did and what NetLogo expects) and other times it exports 2 lines “dx” and “dy”.
Of course someone can go in and edit the header but it makes for confusing output that sometimes works and sometimes does not.
Michael
On Mon, Mar 9, 2015 at 5:55 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
It did not do it well before and we are having trouble finding what to pick to get this (it doesn’t help that the list of output formats is not sorted for some reason). We don’t see an ESRI ASCII or ASC format.
AAIGrid (rw): Arc/Info ASCII Grid?
Michael
C. Michael Barton
USA
On Mar 9, 2015, at 2:50 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
On Mon, Mar 9, 2015 at 5:47 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
Anna
Any suggestions?
Michael
C. Michael Barton
USA
On Mon, Mar 9, 2015 at 11:20 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
I would expect that r.out.gdal can take care of that.
not.
This happens in case of non-square pixels:
http://www.gdal.org/frmt_various.html
"If pixels being written are not square (the width and height of a
pixel in georeferenced units differ) then DX and DY parameters will be
output instead of CELLSIZE."
So you may control that with g.region prior to r.out.gdal.
