[GRASS-dev] what if: Anything series?
      It seems impossible to doubt that everything in
      the universe can be represented by numbers [...]
        -- N. I. Lobachevsky
  Reading ``Time series in GRASS'' page [1], as well as [2, 3],
  made me wonder, is time the only parameter one may need to lay
  the data sets along of? Arguably, it's not.
  Consider, for example, one having to compare the behaviour of
  MM5 modelling results with different models or parameters used.
  There, related rasters are laid along the model index or model
  parameter's value.
  Another example are the rasters comprising of the values of a
  meterological variable for certain (often non-uniformly spaced)
  values of pressure. These sets of raster data sets shouldn't be
  turned into 3D rasters, since the pressure to height
  correspondence varies over space and time.
  The above makes me believe that the generic facility to keep the
  relations between the rasters is necessary. Besides,
  implementing this facility allows for several other problems to
  be addressed within its framework, as I'd try to show below.
* Several related rasters: a rasterset?
  Both of the examples above suggested using numeric values to
  represent the relationship between the rasters. These values
  can include:
  * timestamp (in seconds since epoch), allowing for time series
    [1];
  * layer's pressure;
  * model index or model parameter;
  * were quality flags applied to the raster (1) or not (0)?
  Let me define rasterset as a named collection of related
  rasters, each unambiguously identified by an arbitrary number of
  the arbitrary numeric values.
  Below, I assume using 2D rasters at the lower level of the
  rasterset implementation, since 3D rasters could easily be
  simulated by a rasterset with a `z' as the parameter.
* Tiled raster storage
  The most simple case of using the rasterset facility is to
  implement tiled raster storage [3].
  Indeed, a tiled raster could be implemented with each tile
  becoming a raster within a single rasterset, and then being
  assigned a pair of numeric parameters -- the indices of the
  tile.
  Since the spatial resolution of the tile may differ (the rasters
  comprising the dataset are almost as independent as the
  individual rasters in GRASS currently), this allows for both the
  whole-NULL tiles (no raster for this tile indices), and for the
  same-value tiles (1x1 raster covering the whole region.)
  For the usage of this feature is supposed to be quite common, I
  believe it needs to be implemented at the ``core'' of the
  rasterset implementation, with the appropriate optimizations
  applied for some common cases.
* Metadata
  Since the rasters comprising the rasterset are allowed to carry
  an arbitrary number of additional numeric parameters, this
  facility could assume handling of certain (though not arbitrary)
  metadata, even in cases where these additional parameters aren't
  strictly necessary for the identification purposes.
  However, with each raster being assigned a category, it's
  possible to associate arbitrary information with it using a
  database connected to the rasterset.
* Color maps
  Color maps are currently tied rather closely to the rasters they
  are used for, making it hardly practical to use different color
  maps for the same rasters. This feature could be used, for
  example, to apply different color maps when displaying the data
  and producing the printed output.
  Would the color maps be detached from the rasters, it may become
  feasible to allow for a color map to be shared among several
  rasters.
  I've already mentioned a raster's parameter as a possible
  substitute for `z' (both for simulating `z' for ordinary 3D
  rasters, and for storing layers of data for which layer index to
  `z' mapping varies over space and time.) Moreover, for digital
  elevation models `z' value is actually the value stored in
  raster. It may be worth investigated whether this relation
  could be turned inside out, to allow for arbitrary value to
  arbitrary value mappings be stored as 2D (or 1D) rasters within
  a rasterset.
  There may be demand for storing quite arbitrary arrays in the
  future as well.
* Scanning radiometers & Time
  Due to the curvature of the Earth surface, a satellite scanning
  radiometer such as MODIS sees certain places on Earth multiple
  times in a short period of time (about 1.48 s for MODIS.)
  These places appear on consequent scans on L2 data. The most
  common practices to deal with this effect are either to average
  the values obtained for the same place, or to take the one value
  that is, after some criterion, superior to the other.
  However, allowing for the scans to be stored independently along
  with a ``time'' value associated with each would allow one to
  analyze these very short-term changes (if any.)
* RDBMS as the backend
  Probably the most appealing feature of the rasterset model is
  its supposed flexibility. As mentioned above, the color maps
  could be represented as the rasters in their very own coordinate
  space, and so could be the ground control points (*).
  With the number of separate data structures to form a raster
  reduced, it could become feasible to put these structures into a
  general purpose RDBMS system, thus partially addressing both the
  disk space and the large number of files in a directory concerns
  [4].
  (*) It's very common for the satellite Level 2 data to specify
  the latitudes and longitudes for the centres of the pixels as
  the separate rasters. These could be mapped directly to the
  specific rasters within the rasterset. See [5] for a related
  feature in GDAL.
* Views
  The names aren't convenient for rasters. For example, I have a
  location full of rasters with the names like:
2007-05-31-grans-std-qual-o3
2007-05-31-grans-std-toto3std
2007-05-31-grans-std-toto3std.qa
2007-05-31-grans-std-toto3stderr
  The total number of the 2D data sets for each day is over 70,
  most of which come in both the ``no quality flags applied'' form
  (without the `.qa' suffix) and the ``standard quality flags
  applied'' one (with one.) And the source data do include even
  more data sets.
  In order to handle this amount of data efficiently the system
  should allow one to limit the namespace to the data sets
  matching arbitrary criterions. I don't consider the GUI
  specifically, since it may become rather tedious to filter the
  g.mlist(1) output with grep(1) in scripts as well.
  The rasterset model seems to be a more appropriate solution.
  And, as suggested in the next section, there could be a way to
  name a specific raster within the rasterset. With this
  functionality available from scripts, one could easily apply
  arbitrary schemes for naming the data sets.
* User interface
  With the rastersets being implemented, GRASS database becomes to
  look much more like a relational one. Since the individual
  rasters are no longer named individually (rather, they share the
  common rasterset name and are identified by the associated
  values of the arbitrary parameters), to access a specific raster
  one would need to issue a query. (Much like accessing a table's
  row with SQL queries.)
  Certainly, to expose the very exciting new features the
  rasterset model could offer, the UI (both the command line and
  the graphical parts) would require a major overhaul. However,
  for the compatibility's sake, it's reasonable to implement the
  current raster accessing interface on top of the rasterset
  facility, thus allowing for the existing code (and therefore
  interface) to be retained.
  Then, there would have to be a mapping of the compatibility
  raster names to the (rastername, parameters) pairs, and the
  corresponding utilities to manage it, both in the library API
  and the UI, like:
GRASS> r.bind \
           raster=compat-airs-2007-05-31-total-ozone.qa \
           rasterset=airs-total-ozone \
     parameter="timestamp=2007-05-31 21:35:24 +0000" \
     parameter="qaflags_p=true"
  Parameters not specified are to be allowed to match all, but not
  any, of the rasters. Thus, it won't be needed to specify the
  individual tile indices for the tiled rasters to mean the whole
  spatial extent of the rasterset. If several rasters match the
  specification, but do not complement each other spatially, an
  error is signalled, like:
GRASS> r.bind \
           raster=dummy \
r.bind: several rasters match the specification
GRASS>
  Importing utilities (r.in.gdal, or r.import) would need to be
  changed early to allow for both the rasterset name and the
  identifying parameters to be specified. The other modules could
  be changed as the time permits.
  The rasters imported may be automatically named according to an
  arbitrary user-specified scheme with the ``hooks'' facility
  being implemented in GRASS. (I hope to present my ideas
  regarding such a facility in a separate posting.)
* Notes for the implementor
  The model described above could be based on the current 2D
  rasters implementation after cleaning it of the extra features
  to be provided by the rasterset model itself.
  Within the model, the 2D rasters facility is the lower level,
  and its interface would need to be changed. For the
  compatibility's sake, the former interface would need to be
  provided by the code layered on top of the rasterset
  implementation.
  The rasterset model is to be implemented mostly from scratch.
[1] http://grass.gdf-hannover.de/wiki/Time_series_in_GRASS
[2] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
[3] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
[4] http://freegis.org/cgi-bin/viewcvs.cgi/grass/gips/gip-0002.txt?rev=HEAD&co
ntent-type=text/vnd.viewcvs-markup
[5] http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
Hi Ivan,
thanks for you impressive suggestions! I have right now added a tiny
contribution from Soeren Gebbert with a few bugfixes from me into
GRASS Addons-SVN:
r.rast4d + tg.* - raster time series SQL support
This is a scripted approach to register time series of raster maps
into a SQLite database. Comes in handy when dealing with thousands
of MODIS maps for example.
        parameter's value.
        can include:
          [1];
        * layer's pressure;
        tile.
* Metadata
* Color maps
        rasters.
        a rasterset.
        future as well.
        [4].
        feature in GDAL.
* Views
        more data sets.
* User interface
        and the UI, like:
GRASS> r.bind \
GRASS> r.bind \
           raster=dummy \
GRASS>
        implementation.
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
Markus Neteler <neteler@osgeo.org> writes:
> Hi Ivan, thanks for you impressive suggestions!
  Thank you for reading it. I hope I'd have the time to
  demonstrate these ideas in a working application.
> I have right now added a tiny contribution from Soeren Gebbert with a
> few bugfixes from me into GRASS Addons-SVN:
  ... May I suggest s/directoy/directory/ on QuickStart.txt?
  Take a look at the minor change for lib/insert_raster.sh as well
  (attached.)
  While I have nothing against implementing time series this
  particular way, I doubt this approach will scale well to cover
  the other areas I had mentioned.
  In particular, I believe that the generic arrays storage
  facility is needed in GRASS for a long time. At the very least,
  the ability to access arbitrary arrays in `r.mapcalc'
  expressions sounds quite appealing to me.
  Implementing this facility would effectively split the raster
  data set implementation into the generic ``raster'' (or
  ``array'') part and the specific ``geospatial'', ``color
  mapping'', and ``who knows what'' ones.
Fixed.
        (attached.)
Looks much more polished. But it looks like bash to me, right?
So far we try to avoid bash-isms in GRASS for portability.
Or will it run with ash, too?
I do agree that the raster part needs a radical renovation. Some
team members also have ideas here - hope it comes true for
GRASS 7.
>> (attached.)
> Looks much more polished. But it looks like bash to me, right? So
> far we try to avoid bash-isms in GRASS for portability. Or will it
> run with ash, too?
  It seems that both `local' and `$(COMMAND)' are available in
  either `dash' or BusyBox' `ash', e. g.:
$ cat test.sh
a=
f () { local a="$1" ; echo "$a" ; }
f "$(echo Hello, world\!)"
echo "\"$a\" is expected to be an empty string"
$ dash test.sh
Hello, world!
"" is expected to be an empty string
$ ash test.sh
Hello, world!
  It's probably reasonable to require a Shell implementation with
  either once you're depending on Shell functions being available.
  I'm not sure that these constructs are mandated by any standard,
  though.
  The `test' (`[ ... ]') command should be generally available as
  well. IIRC, it's mandated by POSIX.
>> In particular, I believe that the generic arrays storage facility is
>> needed in GRASS for a long time. At the very least, the ability to
>> access arbitrary arrays in `r.mapcalc' expressions sounds quite
>> appealing to me.
>> Implementing this facility would effectively split the raster data
>> set implementation into the generic ``raster'' (or ``array'') part
>> and the specific ``geospatial'', ``color mapping'', and ``who knows
>> what'' ones.
> I do agree that the raster part needs a radical renovation. Some team
> members also have ideas here - hope it comes true for GRASS 7.
  Are these collected anywhere on the Web (besides of [1, 2])?
[1] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
[2] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
>> (attached.)
> run with ash, too?
$ cat test.sh
a=
$ dash test.sh
Hello, world!
$ ash test.sh
Hello, world!
        though.
I would leave this to others - I am not much expert of POSIX.
>> appealing to me.
>> what'' ones.
AFAIK some material was collected in the Wiki from mailing
list discussions:
http://lists.osgeo.org/pipermail/grass-dev/
More is scattered around in the list archive.
(use e.g.
http://www.nabble.com/forum/Search.jtp?query=raster+format&sort=date&local=y&forum=1200
to find more).
>> though.
  On the other hand, the change to use just one `sed' invocation
  is probably worth applying anyway.
>>> team members also have ideas here - hope it comes true for GRASS
>>> 7.
> AFAIK some material was collected in the Wiki from mailing list
> discussions: http://lists.osgeo.org/pipermail/grass-dev/
> More is scattered around in the list archive. (use e.g.
> to find more).
  ACK. Thanks.
Ivan Shmakov <ivan@theory.asu.ru> writes:
>>> (attached.)
>> run with ash, too?
> It seems that both `local' and `$(COMMAND)' are available in either
> though.
  Apparently, the $(COMMAND) substitution is mandated by IEEE Std
  1003.1 (AKA POSIX) [1]. On the contrary, the `local' keyword
  isn't available as per [2].
> The `test' (`[ ... ]') command should be generally available as well.
  The `test X -lt Y' form is also available [3].
  Hence, I suggest the attached patch instead of the former one.
[1] http://www.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.html#tag_02_06_03
[2] http://www.opengroup.org/onlinepubs/009695399/utilities/xcu_chap02.htm
[3] http://www.opengroup.org/onlinepubs/009695399/utilities/test.html
Thanks, Ivan,
I have uploaded your patch to GRASS-addons.
>>> (attached.)
>> run with ash, too?
> though.
