[GRASS-dev] What is a binary executable doing in CVS?
Why are we including what appears to be a MacOSX binary for GNU make
in CVS (gem/skeleton/macosx/bin/make)? We wouldn't normally store
binary executables in CVS.
Apart from anything else, this obligates us to either host the source
code for that version of make, or offer to provide the source code
upon request for three years from the time that the binary is no
longer available via CVS. Do we even know which version of the source
code we need to supply?
Oops, that's a leftover from pre-CVS development of GEM.
Just delete it if you want.
Binary make versions were planned for deploying pre-compiled extension
modules on systems that don't have C development tools installed.
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
Unfortunately, "cvs remove" won't suffice, because the file will still
be available from CVS using an explicit revision.
We either need to add the corresponding source code to CVS (a tarball
would suffice, but it needs to be the correct version), or have
someone manually remove the ,v file from the repository.
Hi Bernhard,
as CVS admin, could you help us with this problem before it
becomes too messy?
thanks,
grass-dev mailing list
grass-dev@grass.itc.it
becomes too messy?
sure...
removed directory gem/skeleton/macosx from the repository.
Bernhard
