Hello,
In the context of the complete revamping of the GRASS GIS GUI startup, the idea is to use the existing demolocation as a possible basis for a direct entry into GRASS GIS without going through complicated location setup (which will then be offered through the data catalog). In that context, I was wondering whether the mysites and point maps in that demolocation are used by anything. I cannot find any in the code. Would there be any opposition to removing them and only leaving the country borders ?
Moritz
On Tue, Aug 4, 2020 at 3:24 PM Moritz Lennert
<mlennert@club.worldonline.be> wrote:
Hello,
Try the "silver searcher" (`ag`)
Fast and accurate:
ag --html mysites
db/db.execute/db.execute.html
38:db.execute sql="INSERT INTO mysites (id,name,east,north) values
(30,'Ala',1657340,5072301)"
lib/db/sqlp/sql.html
137:v.db.select mysites where="id LIKE 'P__'"
140:v.db.select mysites where="id LIKE 'P%'"
Would
borders ?
Fine for me, esp. with the new purpose of making even better use of
"demolocation".
Just these few usages should be replaced.
Hello,
Fast and accurate:
ag --html mysites
Just a simple grep found those ;-), but comparing those to the mysites file in the demolocation indicatates that these examples have no relation with the mysites map in the demolocation.
There is no id field in the mysites maps, and certainly no name, east nor north...
Moritz
