[GRASS-dev] Where should the file python-wxversion be located?
All:
Where should the file python-wxversion be located so that GRASS 6.4.1 will find it? It's located on my Ubuntu 11.0.4 distribution at:
/usr/share/pyshared-data/python-wxversion
and contains this:
[python-package]
format = 1
python-version = 2.6, 2.7
[pycentral]
version = 0.6.11
include-links = 0
[files]
/usr/lib/python2.6/dist-packages/wxversion.py=f
/usr/lib/python2.7/dist-packages/wxversion.py=f
Tom
Hi Tom,
I'm not sure if this helps you, but I have GRASS7 running on Ubuntu 11.04
and this is where python-wxversion is located on my machine.
justinjent@ubuntu:~$ locate wxversion
/usr/lib/python2.6/dist-packages/wxversion.pyc
/usr/lib/python2.7/dist-packages/wxversion.pyc
/usr/share/doc/python-wxversion
/usr/share/doc/python-wxversion/changelog.Debian.gz
/usr/share/doc/python-wxversion/copyright
/var/lib/dpkg/info/python-wxversion.list
/var/lib/dpkg/info/python-wxversion.md5sums
/var/lib/dpkg/info/python-wxversion.postinst
/var/lib/dpkg/info/python-wxversion.preinst
/var/lib/dpkg/info/python-wxversion.prerm
justinjent@ubuntu:~$gedit /usr/share/pyshared-data/python-wxversion
[python-package]
format = 1
[pycentral]
version = 0.6.11
include-links = 0
[files]
I followed this page when I compiled GRASS7
<http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu>
Justin Jent
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Where-should-the-file-python-wxversion-be-located-tp6502667p6502776.html
  Problem resolved.
Thanks to all who responded; Justin your information helped a lot — after the suggestions and even more digging and some more installs using http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu (which may have helped some in terms of my original problem of not getting wxpython to work for me), but definitely helped to get additional capability in my build.
In the end I had competing python installs: /usr/bin and /usr/local/bin — so, I deleted the /usr/local/bin install of python; wx-config was only present in /usr/bin
I strongly suggest new Umbutu GRASS users to follow http://grass.osgeo.org/wiki/Compile_and_Install_Ubuntu
Tom
On 6/21/11 11:18 PM, jentjr wrote:
Hi Tom,
[python-package]
format = 1
[pycentral]
version = 0.6.11
include-links = 0
[files]
Justin Jent
grass-user mailing list
grass-user@lists.osgeo.org
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
