[GRASS-dev] Which is the correct WIND convention for creating a new mapset?
Hello all,
I am a bit confused WRT what the expected WIND should be when you create a new mapset.
Some functions copy DEFAULT_WIND from PERMANENT. E.g.:
with kind regards,
Panos
On Mon, May 6, 2019 at 6:21 PM Panagiotis Mavrogiorgos <pmav99@gmail.com> wrote:
Hello all,
lib/gis/make_mapset.c
pygrass.gis.make_mapset()
the grass executable
While others copy WIND from PERMANENT. E.g.
the tests
gui.wxpython.startup.create_mapset()
Is there an established convention?
IMHO, new mapsets should use DEFAULT_WIND from PERMANENT. But the current region of a new mapset is often adjusted, therefore it does not really matter if DEFAULT_WIND or WIND is used.
my2c
Markus M
On Mon, May 6, 2019 at 9:38 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hello all,
Thank you Markus, that’s what I expected, too.
I don’t disagree, but still, I don’t see what’s the benefit of not using the same convention everywhere. Furthermore, I truly don’t understand why 4 different implementations are needed.
with kind regards,
P.
On Tue, May 7, 2019 at 10:20 AM Panagiotis Mavrogiorgos <pmav99@gmail.com> wrote:
Hello all,
True, g.mapset -c should be used whenever possible. I adjusted the wxGUI startup wizard and the tests in trunk r74472,3 (the tests should use g.mapset -c, not yet implemented)
Markus M
On Tue, May 7, 2019 at 11:03 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Hello all,
I would argue that it is G_make_mapset() that should be used whenever possible :slight_smile:
(which of course, is being used by g.mapset -c, too)
I think that in the nc_spm_full_v2alpha dataset WIND and DEFAULT_WIND differ, so 74473 might break any tests that don’t explicitly set the region themselves (which of course they should). We will see.
P.
On Wed, May 8, 2019 at 10:22 AM Panagiotis Mavrogiorgos <pmav99@gmail.com> wrote:
Hello all,
It depends. g.mapset changes the current mapset (and location and database). It might also create a new mapset in an existing location, but it always switches. If that switch is not desired, GISRC must be adjusted to the original GRASS session. G_make_mapset() is a C function and should be used by C modules. Of course you could use it with pygrass, but pygrass initializes the GRASS C libraries, and you need to take care that initializations are properly updated when changing mapsets (and locations). Creating a new mapset in an existing location is not difficult: create the folder and copy DEFAULT_WIND from PERMANENT to WIND in the new mapset. Maybe create a new function create_mapset() in lib/python/script/utils.py?
IMHO, tests need to set the region themselves, just as users. The current region is such a fundamental concept of GRASS (raster processing) that I regard it as a mistake if the current region is not explicitly set to actual demands.
Markus M
Thank you markus
On Wed, May 8, 2019 at 10:54 PM Markus Metz <markus.metz.giswork@gmail.com> wrote:
Generally speaking, I think it is important that the API comes first. Once some functionality has been implemented in a library it can then be exposed to the end users in multiple ways (e.g. CLI, REST, whatever). Among other things, by implementing the API first, it is much easier to test the code + you follow DRY.
This is why I mentioned “G_make_mapset()” which seems to already be implementing this functionality and which, as you mentioned, is exposed to Python via pygrass. The idea is that if in the future the process of creating a mapset becomes more complicated, then we would only have to update “G_make_mapset()”. That being said I am not familiar enough with the initialization process so I can’t really argue if a pure python implementation is needed or not.
Now to become more specific, as an API user, I think would find it strange that calling the “create_mapset()” function also changes the current mapset. I like it when things are explicit + it makes it easier to document and test. As far as implementing “create_mapset()” in lib/python/script/utils.py, why not move the relevant functions from “gui/wxpython/startup/utils.py” and have the GUI code import them from the “grass” lib?
BTW, those functions do need a few improvements; e.g. rename_mapset() should fail to rename PERMANENT etc, but let’s move them first and we can do that later.
I completely agree that tests that don’t set the region themselves should be fixed.
all the best,
Panos
On Thu, May 9, 2019 at 10:01 AM Panagiotis Mavrogiorgos <pmav99@gmail.com> wrote:
Thank you markus
In this particular case I think a Python implementation would help because 1) it is really simple to create a new mapset in any existing location, 2) the overhead of using pygrass is not needed in this case: most important developer’s rule: keep it as simple as possible.
the suggested new function “create_mapset()” should only create a new mapset, check if it succeeded in doing so, and not change to the new mapset. The idea is that any python code that wants to create a new mapset does not use its own method but instead uses this new function from lib/python/script/utils.py.
Markus M
