I am trying to compile some code that calls the function
CC_u2ll_spheroid_parameters. I have included CC.h and included
libgrass_gproj.so and libgrass_gmath.so in the makefile but the code
isn't compiling.
I get an error: "undefined reference to 'CC_u2ll_spheroid_parameters'.
I would be grateful of any help.
which library has CC_u2ll_spheroid_parameters?
In GRASS 6.4 source code I only see include/CC.h, but in the GRASS 5.4
source code there is ./src/libes/coorcnv/utm.c which includes the
CC_u2ll_spheroid_parameters() function if you need it.
> isn't compiling.
CC.h should have been removed along with the rest of the coorcnv
library. Fixed in r43658 (trunk).
Anything intended to work with current versions of GRASS should use
PROJ, either directly or via libgrass_gproj. The coorcnv libray was an
artifact of the days when GRASS only understood UTM and State Plane;
it was "legacy" code even in 5.x.
Looking for a function for converting pixel's coordinates to
geocentric x y z, I've found that CC_ll2geo definition is still
included in the code - generating documentation here http://grass.osgeo.org/programming6/CC_8h.html. It was a bit
misleading to find the declaration but not the definition.
Is there some example around to perform conversion of pixel's
coordinates to geocentric x y z using libgrass_gproj?
> isn't compiling.
