[GRASS-dev] Which v.* modules are working with v.external'ed data
Background of the question in subject: the GRASS algs in upcoming QGIS3 are
working with v.external linked data.
I've seen some modules doesn't work with such kind of data.
Is there maybe a list already available?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
I’ve seen some modules doesn’t work with such kind of data.
It depends also on the format that is linked in with v.external. For all formats that do not have a key column (e.g. shapefile), attributes are not accessible, and attributes would get lost when modifying the geometries.Therefore it is generally not safe to link vector data with v.external. In many cases it does not make sense to use v.external linked data with simple features, instead vector data should be imported to get true topology. If upcoming QGIS3 is working with v.external linked data, the GRASS interface of QGIS is effectively broken.
Markus M
Markus Metz-3 wrote
On Wed, Nov 15, 2017 at 1:36 PM, Helmut Kudrnovsky &lt;
hellik@
are
Markus M
grass-dev mailing list
grass-dev@.osgeo
https://lists.osgeo.org/mailman/listinfo/grass-dev
in QGIS 3 options, a switch to v.in.ogr is possible..
I think we should communicate to the QGIS devs that v.external isn't the
best choice.
best regards
Helmut
2017-11-15 16:01 GMT+01:00 Helmut Kudrnovsky <hellik@web.de>:
best choice.
absolutely, I can imagine linking point data. But generally, import
should be default option. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
On Wed, Nov 15, 2017 at 3:49 PM, Markus Metz
are working with v.external linked data.
I have turned this into a potential new snippet for the v.external manual:
----- snip -----
Due to these data model differences <em>v.external</em> does not work
with all data formats. In general, for all formats that do not have a
key column (e.g. SHAPE file), attributes are not accessible, and attributes
would get lost when modifying the geometries. Therefore it is generally
not safe to link vector data with <em>v.external</em>. In many cases it
does not make sense to use <em>v.external</em> linked data with simple
features, instead vector data should be imported with <em>v.import</em>
or <em>v.in.ogr</em> to get true topology support. Importantly, point
cloud data which do not have topology, can be linked with <em>v.external</em>.
----- snap -----
Please review.
----- snip -----
Due to these data model differences v.external does not work
features, instead vector data should be imported with v.import
or v.in.ogr to get true topology support. Importantly, point
cloud data which do not have topology, can be linked with v.external
as long as there are no attributes attached to these point cloud data, or if the format of the point cloud data has a key column that allows to link vector geometries to attributes.
----- snap -----
Please review.
Importing point cloud data is fast, therefore there is little gain in using v.external instead of v.in.ogr.
Markus M
On Wed, Nov 15, 2017 at 10:03 PM, Markus Metz
> not
> linked
> the
----- snip -----
attributes
<em>v.external</em>
Thanks, added in r71743 (and backported).
----- snap -----
Please review.
I wonder how much disk space that would save?
markusN
not
linked
the
----- snip -----
attributes
v.external
----- snap -----
Please review.
I wonder how much trouble corrupt or no output will cause?
Markus M
best choice.
Just done in the related pull request for GRASS GIS support.
markusN
Just for the record: some of my colleagues are making quite extensive use of v.external for GPS tracking (point) data they have in PostGIS. Earlier we tried to use PostGIS rasters, but it is much more convenient and efficient to e.g. just upload raster values to linked PostGIS tables from GRASS, now that v.what.rast does not require topology any more…
Stefan
not
linked
the
----- snip -----
attributes
v.external
----- snap -----
Please review.
Markus M
