[GRASS-dev] why d.vect.thematic won't run on WinGRASS - d.mon problem
On Jan 24, 2008, at 2:54 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Thu, 24 Jan 2008 10:53:51 +0000
Subject: Re: [GRASS-dev] why d.vect.thematic won't run on WinGRASS -
  d.mon problem
To: Michael Barton <michael.barton@asu.edu>
Cc: GRASS developers list <grass-dev@lists.osgeo.org>
Message-ID: <18328.28223.869808.987628@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
Michael Barton wrote:
If you just want d.vect.thematic to work with WinGRASS, changing it to
use GRASS_RENDER_IMMEDIATE=TRUE instead of "d.mon start=PNG" would
probably be less work than getting monitors working.
In fact, we recently had to change d.vect.thematic to set
GRASS_RENDER_IMMEDIATE=FALSE so that it's multiple iterations of
d.vect would composite in the PNG monitor and then be output as a PNG
to the GUI.
You can use GRASS_PNG_READ=TRUE to have it read an existing file at
startup, rather than starting with a blank "screen". That way, each
command will overlay the output from previous commands.
Glynn,
This sounds like it might be a way out of this dilemma. Can you explain this setting a it more? Also, once all the commands are overlayed is there someway to get them to output to a PNG or PNM so that the GUI can pick it up--since we can't do it with d.mon stop=PNG?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
    d.mon problem
to the GUI.
--Glynn Clements <glynn@gclements.plus.com>
Glynn,
GRASS_RENDER_IMMEDIATE=TRUE always outputs a PNG or PNM file (depending on the setting of GRASS_PNGFILE. As the manual on the PNG env variables says: if you set GRASS_PNG_READ to "TRUE", "the PNG driver will initialize the image from the contents of $GRASS_PNGFILE", i.e. it will read the contents of $GRASS_PNGFILE and adds the results of your drawing command to it. The output thus still is $GRASS_PNGFILE.
Moritz
Michael
Phone: 480-965-6262
Fax: 480-965-7671
grass-dev mailing list
So it builds the PNG as it goes, and then the TclTk GUI could grab the completed composite when it's done?
This sounds almost too good to be true.
Michael
Phone: 480-965-6262
Fax: 480-965-7671
    d.mon problem
to the GUI.
Glynn,
Moritz
Michael
Phone: 480-965-6262
Fax: 480-965-7671
grass-dev Info Page
That's how I understand the docs. Just watch out to set GRASS_PNG_READ back to FALSE after d.vect.thematic finishes...
Glynn is too good to be true :wink:
Moritz
I'm going to try this as soon as I can steal a bit of time. I'm somewhat uncertain how to get the initial PNG for GRASS_PNG_READ.
I can create a dummy temp map using r.mapcalc and then save it to a PNG using r.out.png. But I need to make sure that it's background is transparent so that the final composite can overlay whatever is in the map display. Any suggestion for how I do that?
Michael
______________________________
School of Human Diversity & Social Change
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Moritz
You don't actually need to create an initial image; if the file
doesn't exist, any GRASS_PNG_READ=TRUE setting will be silently
ignored. If the file does exist, the dimensions and depth must match
the values of $GRASS_WIDTH, $GRASS_HEIGHT and $GRASS_TRUECOLOR.
You can create a blank image with "d.frame -e" or "d.erase -f". If
GRASS_TRANSPARENT=TRUE, the image will be transparent, otherwise it
will be filled with $GRASS_BACKGROUNDCOLOR. This works both with
direct rendering and the PNG driver. Note that "d.erase" alone is
equivalent to "d.erase color=white". There isn't any way to clear a
portion of the screen to transparent, only the entire screen.
Does d.erase work if there are no monitors?
Michael
USA
It works with direct rendering.
d.erase just fills a rectangle in a specific colour. "d.erase -e" is
different in that it uses the R_erase() function (as does
"d.frame -e"), which corresponds to the ERASE opcode.
The PNG driver library (used by both the standalone driver and direct
rendering) responds to this opcode by clearing the image, making it
transparent if GRASS_TRANSPARENT=TRUE.
The only program which fundamentally doesn't work with direct
rendering is d.mon.
A few other programs aren't much use with direct rendering as they
rely upon operations which aren't implemented.
The main issue with direct rendering is that there is no persistence
between commands. This makes d.font useless, and d.frame mostly
useless ("d.frame -e" works to erase the screen, but you can't create
persistent frames).
Obviously, mouse interaction doesn't work, but that's also true of the
PNG driver (and all drivers except XDRIVER). Panels (the ability to
save and restore regions of the screen) don't work with either the PNG
driver or direct rendering, but they're only ever used in conjunction
with mouse interaction.
