[GRASS-dev] why is r.li.setup unavailable in GRASS 7?
Why is r.li.setup unavailable in GRASS 7? It is greyed out in the menu and cannot be launched from the command line. Without this, you cannot use the other r.li modules. But I also see tickets that indicate r.li.setup has been happening very recently.
Michael
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Tue, Oct 30, 2012 at 6:38 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
The code is still here:
http://trac.osgeo.org/grass/browser/sandbox/lucadelu/r.li.setup.py
and requires testing before being migrated to trunk.
Yes, to test you can call directly "python r.li.setup.py " from the directory where you downloaded the file.
I worked on it last week and I compared the resulting setup files of python and tcl/tk and they are identical.
Right now not all the functionality of tcl/tk are implemented, but I’d like to move it from sandbox to trunk…
Luca
OK. I’ll try to test as soon as possible, though hopefully others with greater familiarity with the r.li modules can help in this. Without r.li.setup, all other r.li modules are useless.
Related to this, the r.le modules appear in the menu but are greyed out. If they are no longer to be distributed with GRASS, they should come out of the menu.
Michael
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
On Oct 30, 2012, at 7:42 AM, Luca Delucchi <lucadeluge@gmail.com>
Luca
2012/10/30 Michael Barton <Michael.Barton@asu.edu>:
OK. I'll try to test as soon as possible, though hopefully others with
I committed right now r.li.setup gui for wxpython. It's possible to
launch from GUI "raster -> Landscape path analisys -> Set up....." or
from command line using g.gui.rlisetup. Missing feature should be
added in the next months and testing is welcome.
I already know a bug if you launch more times the wizard from the
second time you can move forward without the name of configuration
file and raster that are mandatory. If someone can help me for this
point....
Michael
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Thanks Luca
______________________________
C. Michael Barton
USA
On Nov 26, 2012, at 4:55 AM, Luca Delucchi <lucadeluge@gmail.com>
point....
Michael
ciao
Luca
www.lucadelu.org
Luca,
r.li.setup does not yet compile in GRASS 7, at least on the Mac.
Here is the error:
anthgradpc7:g.version cmbarton$ cd /Users/Shared/grass_dev/grass7_dev/gui/wxpython/rlisetup
anthgradpc7:rlisetup cmbarton$ make
if [ "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup" != "" ] ; then GISRC=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/demolocation/.grassrc70 GISBASE=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0 PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:$PATH" PYTHONPATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:" LC_ALL=C /Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.rlisetup.tmp.html ; fi
  File "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup", line 32, in <module>
    import wx
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
    import _core_
ImportError: /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
make: *** [g.gui.rlisetup.tmp.html] Error 1
rm g.gui.rlisetup.tmp.html
This may be the same error that is now affecting several GUI modules like map swipe, animation, and the graphical modeler.
Michael
C. Michael Barton
USA
On Nov 26, 2012, at 8:42 AM, Michael Barton <Michael.Barton@asu.edu> wrote:
Thanks Luca
C. Michael Barton
USA
point....
Michael
ciao
Luca
www.lucadelu.org
2012/12/1 Michael Barton <Michael.Barton@asu.edu>:
Luca,
Hi Micheal
I'm sorry :frowning:
Here is the error:
    import wx
    import _core_
This seems more a WX problem...I know that it's a "stupid" answer but
could you try
import wx
from python console?
Michael
ciao
Luca
www.lucadelu.org
Luca,
Hi Micheal
Here is the error:
    import wx
    import _core_
could you try
import wx
Just a remark:
This problem affecting map swipe, animation, graphical modeler and
r.li.setup is spread in several threads which makes it more
complicated to follow. What about to choose one of them?
subjects:
compiling animation, mapswipe, etc.
problems compiling GRASS 7 on Mac
Compiling under OSX Mountain Lion
Best,
Anna
Michael
ciao
Luca
www.lucadelu.org
Hmm, everyone having these "errors" - is it during compilation or at runtime?
I thought at first it was runtime, based on the isolated quoting of the error only, and this would make it very mysterious since the Mac compilation creates a 32bit python wrapper exactly for this problem.
But Michael's error quote shows it at compilation time. this makes much more sense - this is where make runs the command to generate help, but at this point the 32bit wrapper is not made yet so the default system python runs in 64bit mode. Michael and I have workied around this by creating a dummy 32bit python wrapper before compilation and putting it in the PATH temporarily.
Did you forget this Michael? I just compiled GRASS 7, with the wrapper in the PATH. no errors.
So, partly a problem of documenting build process, partly a makefile problem.
I've been lazy updating the Mac build readme, too much change trying to figure out weirdness like this. For this problem, I guess I was hoping we wouldn't have to deal with the 32/64bit wxPython problem for long, that wxPython devs would figure out Cocoa for 64bits sooner than they did (2.9 is still technically beta). Then you'd have a wxPython for the default system arch (64bit starting with Snow Leopard, though you'd have to install it) and make would just work, and there would be no need for a wrapper before or after compilation.
I vaguely remember suggesting moving the wrapper build to the beginning of the make process, but was vetoed.
Luca,
Hi Micheal
Here is the error:
   import wx
   import _core_
could you try
import wx
Just a remark:
subjects:
Best,
Anna
Michael
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
Did did run the 32 bit wrapper command prior to compilation--or I thought so. Maybe I got mixed up with too many terminal windows open. I'll try again over the next few days when I have a bit of time.
Has anyone out there tried to compile GRASS with wxPython 2.9 to see where the glitches are?
Michael
C. Michael Barton
On Dec 1, 2012, at 10:49 AM, William Kyngesburye <woklist@kyngchaos.com>
Luca,
Hi Micheal
Here is the error:
  import wx
  import _core_
could you try
import wx
Just a remark:
subjects:
Best,
Anna
Michael
ciao
Luca
www.lucadelu.org
grass-dev Info Page
- Marvin
Just a remark:
subjects:
or opening a bug ticket?
maybe another bug for mapswipe:
http://trac.osgeo.org/grass/ticket/1817
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/why-is-r-li-setup-unavailable-in-GRASS-7-tp5012136p5020147.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
