Today I've just realize that the parameter of g.region are defined as string:
http://trac.osgeo.org/grass/browser/grass/trunk/general/g.region/main.c#L203
for example:
parm.north = G_define_option();
parm.north->key = "n";
parm.north->key_desc = "value";
parm.north->required = NO;
parm.north->multiple = NO;
parm.north->type = TYPE_STRING;
parm.north->description = _("Value for the northern edge");
parm.north->guisection = _("Bounds");
Why should we not use TYPE_DOUBLE for these parameters (n,s,e,w,)? Is
it to not loose significant digits?
Sorry if this has already been discussed, but I was not able to find
any reference in the mailing-list's archive.
Best regards
Pietro
On 08/12/2013 05:39 PM, Pietro wrote:
[snip]
It needs to be a string, so that you can use
common lat/lon notations in the format "°dd'mm''ss".
Ben
Best regards
Pietro
grass-dev mailing list
grass-dev@lists.osgeo.org
Dr. Benjamin Ducke, M.A.
{*} Geospatial Consultant
{*} GIS Developer
benducke@fastmail.fm
On Mon, Aug 12, 2013 at 4:54 PM, Benjamin Ducke <benducke@fastmail.fm> wrote:
Thank you Ben! I didn't thought to the lat/lon notation.
Best regards
Pietro
Hamish
4
Ben:
technically it's like ddd:mm:ss.ssssH.
see the v.in.ascii man page. fwiw GMT mapping uses something similar.
regards,
Hamish
ps- the wxgui loc'n wizard still doesn't support that?
