[GRASS-dev] Wiki: GRASS compile howto updated
I have updated the
Compile and Install Howto:
http://grass.gdf-hannover.de/wiki/Compile_and_Install
Please review,
Hi Markus,
Maybe a newbie note, but it may help for comprehension.
For --with-glw, which software homepage to look for?
and similarly for non-obvious configure options.
Thank you,
Yann
2006/5/28, Markus Neteler <neteler@itc.it>:
I have updated the
Please review,
grass-dev mailing list
grass-dev@grass.itc.it
I've been thinking I need to update (and simplify) the Mac OS X build instructions. Maybe I should take the opportunity to transfer them to the wiki?
On May 28, 2006, at 5:43 AM, Markus Neteler wrote:
I have updated the
Please review,
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
The --with-glw option no longer has any use. It used to be required
for r3.showdspf, but that module is no longer built regardless of
configure switches. AFAIK, it has been made obsolete by recent version
of NVIZ.
FWIW, there are two implementations of the GLw library, from:
  http://www.x.org/ (part of X11)
or:
  http://www.mesa3d.org/ (part of Mesa)
Other libraries which may be used but which aren't documented in
REQUIREMENTS.html are:
FFMPEG: http://ffmpeg.sourceforge.net/index.php
OpenDWG: http://www.opendesign.com/
