Now, here comes my second problem (ref. "Windows - Bug in path handling" for the first one). System: Windows 7 Prof. 64 Bit, german.
I removed GRASS GIS and reinstalled it to "c:\GRASS_GIS", a destination path without spaces to overcome my first problem. Then the startup goes one step further and stops again. Here is the output:
¦ Cleaning up temporary files...
¦ Starting GRASS GIS...
¦ Traceback (most recent call last):
¦ File "C:\GRASS_GIS\gui\wxpython\gis_set.py", line 32, in <module>
¦ from core.utils import _
¦ File "C:\GRASS_GIS\gui\wxpython\core\utils.py", line 25, in <module>
¦ from grass.script import task as gtask
¦ File "C:\GRASS_GIS\etc\python\grass\script\task.py", line 35, in
¦ <module>
¦ from xml.parsers import expat # TODO: works for any Python?
¦ File "C:\PYTHON26\LIB\xml\parsers\expat.py", line 4, in <module>
¦ from pyexpat import *
¦ ImportError: DLL load failed: %1 ist keine zulõssige Win32-Anwendung.
¦ FEHLER: Error in GUI startup. See messages above (if any) and if
¦ necessary, please report this error to the GRASS developers.
¦ On systems with package manager, make sure you have the right GUI
¦ package, probably named grass-gui, installed.
¦ To run GRASS GIS in text mode use the -text flag.
¦ Use '--help' for further options
¦ grass72 --help
¦ See also: https://grass.osgeo.org/grass72/manuals/helptext.html
The german part of the output means:
ImportError: DLL load failed: %1 is not a valid Win32 applicatian
I tried both - GRASS GIS 32 Bit as well as the 64 bit variant. Neither of them works.
¦ <module>
AFAIU you're using winGRASS standalone installer. Correct? Which Version?
winGRASS standalone bundles its own python version.
¦ ImportError: DLL load failed: %1 ist keine zulõssige Win32->Anwendung.
here it seems to point to an external python living in C:\PYTHON26.
Have you more python version installed on your Windows System?
these several python installations may interfere.
Could you rename C:\PYTHON26 to e.g. C:\xxxxPYTHON26 and try to restart
winGRASS and post the results here?
Am 31.05.2017 um 21:34 schrieb Helmut Kudrnovsky:
>> ¦ <module>
Yes. V7.2.1.
Helmut, you are great!
I was not aware of this old Python installation any more (presumable a left-over from an old Blender setup). Removing it solved both problems I had.
However, I may install a new blender in near future. As far as I know, it still comes with a separate Python installation.
Any idea on how to avoid such interferences in the future?
