[GRASS-dev] Windows compilation failed
Hi All,
I tried to install Grass source on Windows 10 using the following link.
https://trac.osgeo.org/grass/wiki/CompileOnWindows
Downloaded the GRASS source from development trunk using the following commands.
cd /usr/src
svn checkout [https://svn.osgeo.org/grass/grass/trunk](https://svn.osgeo.org/grass/grass/trunk) grass_trunk
On Compilation , it failed with following errors.
Started compilation: Tue Dec 12 12:47:54 IST 2017
Errors in:
/usr/src/grass_trunk/raster/r.in.lidar
/usr/src/grass_trunk/raster3d/r3.in.lidar
/usr/src/grass_trunk/vector/v.out.lidar
/usr/src/grass_trunk/vector/v.in.lidar
In case of errors please change into the directory with error and run ‘make’.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
</FINAL ERROR>
On running the make in r.in.lidar directory. it failed with following error.
C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/bin/r.in.lidar.exe: error while loading shared libraries: libgrass_raster.7.5.svn.dll: cannot open shared object file: No such file or directory
make: *** […/…/include/Make/Html.make:14: r.in.lidar.tmp.html] Error 1
</RASTOR ERROR>
I have also noticed many related to header files in package.log file. Please find the some of the errors for your reference.
<HEADER_ERRORS>
Status: Preprocessing c:/users/work/appdata/local/temp/tmpgupeez.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG -U GNUC -dD “-Dinline=” “-D__inline__=” “-D__extension__=” “-D_Bool=uint8_t” “-D__const=const” “-D__asm__(x)=” “-D__asm(x)=” “-DCTYPESGEN=1” c:/users/work/appdata/local/temp/tmpgupeez.h
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: In file included from C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:275:0,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from C:/msys64/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: from c:/users/work/appdata/local/temp/tmpgupeez.h:1:
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error VARARGS not implemented for this compiler
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: #error VARARGS not implemented for this compiler
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64 -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -I/usr/src/grass_trunk/dist.x86_64-w64-mingw32/include -D__GLIBC_HAVE_LONG_LONG: ^~~~~
Status: Parsing c:/users/work/appdata/local/temp/tmpgupeez.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:176: Syntax error at ‘va_list’
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax error at ‘va_list’
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:188: Syntax error at ‘va_list’
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:193: Syntax error at 'va_list
</HEADER_ERRORS>
Please help us in resolving the above errors.
  • Thanks
    CM Reddy
regarding the lidar errors, have look into
/mswindows/OSGeo4W/package.sh
155 if [ "$MINGW_POSTFIX" = "64" ]; then
156 conf_host=x86_64-w64-mingw32
157 # see https://trac.osgeo.org/osgeo4w/ticket/539#ticket
158 # LAS support only enabled on 64bit
159
conf_opts="--with-liblas=$PWD/mswindows/osgeo4w/liblas-config"
160 else
161 conf_host=i386-w64-mingw32
162 conf_opts=
163 fi
change line 159 to the same as line 162:
conf_opts=
no trailing whitespace or similar
then compilation should work, though the lidar modules aren't available
then; that has to be hopefully fixed at some time.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
CM Reddy wrote
Hi All,
commands.
cd /usr/src
svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
<FINAL ERROR>
Errors in:
'make'.
disabled now lidar modules in winGRASS trunk, winGRASS 74 svn and winGRASS
72 svn:
[GRASS-SVN] r71920 - grass/trunk/mswindows/osgeo4w svn_grass at osgeo.org
[GRASS-SVN] r71921 - grass/branches/releasebranch_7_4/mswindows/osgeo4w
[GRASS-SVN] r71922 - grass/trunk/mswindows/osgeo4w svn_grass at osgeo.org
[GRASS-SVN] r71923 - grass/branches/releasebranch_7_2/mswindows/osgeo4w
compilation of winGRASS should work now, though without lidar modules.
test by 'svn up' your code and try a new compilation by 'make distclean'
followed by the wiki command.
best regards
Helmut
CM Reddy wrote
Hi All,
commands.
cd /usr/src
<FINAL ERROR>
Errors in:
'make'.
see comment in ticket: https://trac.osgeo.org/osgeo4w/ticket/550#comment:2
hobu:
This was caused by me. I updated LASzip, but libLAS hasn't been updated to
use the new LASzip API. You'll have to revert to the LASzip 2.2.0 version to
use libLAS
best regards
Helmut
