[GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
Thanks for all the suggestions: I modified the document, and finally it
sounds good for me:
http://www.webalice.it/marco.pasetti/temp/README.html
So, let's start the poll! :wink:
Marco
On Thu, March 27, 2008 22:46, Marco Pasetti wrote:
sounds good for me:
Just one last remark: IIRC, for PostgreSQL you only provide the libpg.dll,
not the entire postgresql installation. This should be mentioned. And what
about sqlite ? Did you include the sqlite.exe ?
Moritz
Marco
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Moritz,
This should be mentioned. And what about sqlite ? Did you include the
sqlite.exe ?
For PostgreSQL I provide only libpq.dll, while for SQLite I provide *all the
build*, that is also sqlite.exe.
On the same way, should I notice also further info for Tcl/Tk (as for
SQLite, I provide *all the build* of it)?
But this would open a *pandora's box*, because on this way I should specify
also what files I exactly provide from other stuffs (such as tiff, gdal,
proj....)
Opened to all suggestions :wink:
Marco
-----Messaggio originale-----
Da: Moritz Lennert [mailto:mlennert@club.worldonline.be]
Inviato: giovedì 27 marzo 2008 22.59
A: Marco Pasetti
Cc: GRASS Developer Mailing List
Oggetto: Re: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
it sounds good for me:
Moritz
Marco
I could solve as adding the following note after "*with GEOS, Expat,
PostgreSQL and SQLite support enabled":
The current WinGRASS package contains a complete build of all the items
listed above, except for PostgreSQL, for which it contains only the
libpq.dll dynamic library.
What do you think about?
A: Marco Pasetti
Moritz
Marco
On Thu, March 27, 2008 23:06, Marco Pasetti wrote:
Hi Moritz,
libpg.dll,
sqlite.exe ?
the
specify
proj....)
personally, I think the information about the GDAL, proj, etc are minor
compared to the info about postgresql.
Maybe you could just add a ** with a note "packages containing libraries
and binaries, all others only contain library files", or something
similar.
Moritz
Marco
A: Marco Pasetti
Moritz
Marco
Hi Moritz,
Maybe you could just add a ** with a note "packages containing libraries and
binaries, all others only contain library files", or something similar.
Please, check if it works for you now. It's late here, and my brain
continues to fail connections (brain ping errors!), so you'll probably need
to fix my english errors :wink:
Goodnight
Marco
Inviato: giovedì 27 marzo 2008 23.23
A: Marco Pasetti
Cc: 'GRASS Developer Mailing List'
Oggetto: Re: R: [GRASS-dev] WinGRASS-6.3.0RC6 Self Installer
Hi Moritz,
libpg.dll,
sqlite.exe ?
*all the build*, that is also sqlite.exe.
specify also what files I exactly provide from other stuffs (such as
tiff, gdal,
proj....)
Moritz
Marco
A: Marco Pasetti
libpg.dll, not the entire postgresql installation. This should be
mentioned. And what about sqlite ? Did you include the sqlite.exe ?
Moritz
Marco
Marco:
tiff, gdal, proj....)
those [ie tiffinfo, gdalinfo, gdalwarp, gdal_translate, and cs2cs] would
all be very useful things to provide.
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hamish,
and, in fact, they are already provided ;-), since RC5
Marco
Da: Hamish [mailto:hamish_b@yahoo.com]
Inviato: ven 28/03/2008 7.40
A: marco.pasetti@alice.it
Cc: ‘GRASS Developer Mailing List’
Marco:
But this would open a pandora’s box, because on this way I should
tiff, gdal, proj…)
Hamish
since new python GUI seems to basically work, do you think that it would better to add to README file infos about it? such as:
New table of contents item:
New Python GUI
We highly recommend you to also test the new GRASS Python GUI. To do that you’ll need to install additional applications:
[…]Python, Python extensions for windows, wxpython and NumPy, as done in the Building Guide[…]
To start GRASS with the new Python GUI, open MSYS shell, type grass63 -wxpython and then enter
What do you think about? (it’s the last issue, I think, about README file; after that I will compile the installer)
Marco
