Moritz Lennert wrote:
1) ODBC and maybe MySQL might be good things to add. Especially the
first, as this would potentially give access to Win-specific databases.Does the ODBC driver work with Windows ODBC?
Yes, you can compile GDAL 1.5 against the MinGW ODBC API, but you need
to adjust the library names in GDALMake.opt.
Have not tried to check it actually works with real data, though.
Benjamin
