[GRASS-dev] winGRASS addons - consolidation/fix release needed!!
hi,
actually, there are several complaints that downloading precompiled winGRASS
addons isn't working, see e.g.
https://trac.osgeo.org/grass/ticket/3455#comment:5
https://lists.osgeo.org/pipermail/grass-web/2019-July/004925.html
https://lists.osgeo.org/pipermail/grass-user/2019-July/080557.html
etc.
checked now the situation of download server URLs and related g.extension
code lines regarding several branches and master:
*grass72
https://wingrass.fsv.cvut.cz/grass72/x86/addons/
[DIR] grass-7.2.2/ 2019-07-07 09:10 -
[DIR] grass-7.2.3/ 2019-07-07 09:10 -
[DIR] latest/ 2019-07-07 09:10 -
https://wingrass.fsv.cvut.cz/grass72/x86_64/addons/
*grass74
https://wingrass.fsv.cvut.cz/grass74/x86_64/addons/
[DIR] grass-7.4.svn/ 2019-07-25 09:06 -
https://github.com/OSGeo/grass/blob/releasebranch_7_4/scripts/g.extension/g.extension.py#L937
    base_url = "http://wingrass.fsv.cvut.cz/" \
               "grass%(major)s%(minor)s/%(platform)s/addons/" \
               "grass-%(major)s.%(minor)s.%(patch)s" % \
               {'platform': platform,
                'major': version[0], 'minor': version[1],
                'patch': version[2]}
*grass76
https://wingrass.fsv.cvut.cz/grass76/x86_64/addons/
[DIR] grass-7.6.svn/ 2019-07-25 09:06 -
[DIR] latest/ 2019-07-25 09:06 -
https://wingrass.fsv.cvut.cz/grass76/latest/addons/
https://github.com/OSGeo/grass/blob/releasebranch_7_6/scripts/g.extension/g.extension.py#L937
*grass77
https://wingrass.fsv.cvut.cz/grass77/x86_64/addons/
[DIR] grass-7.7.dev/ 2019-07-25 09:06 -
https://github.com/OSGeo/grass/blob/master/scripts/g.extension/g.extension.py#L1021
in the MLs there are some suggestions for workarounds, e.g.
in https://trac.osgeo.org/grass/ticket/3455#comment:6
following change is suggested:
                #'patch': version[2]}
                'patch': 'svn'}
the same in
https://lists.osgeo.org/pipermail/grass-user/2019-July/080526.html
            #'patch': version[2]} # comment this out
            'patch': 'svn'} # add this
see e.g.
https://lists.osgeo.org/pipermail/grass-user/2019-July/080561.html
shows that, with the workaround, a GRASS GIS library mismatch issue may
occur.
* for the short term, we need a winGRASS addon consolidation and a fix
release; our winGRASS users seem to use the addons in a regular way
* for the long term, buidling winGRASS addon via appveyor (compare e.g.
https://pdal.io/development/compilation/windows.html) may be another way to
deliver them.
in another thread a discussion started how GRASS GIS should handle addons
after the GIT switch: central repo vs. distributed addon repos.
short and long term ideas/solutions for winGRASS addons mentioned above are
related to the question central repo vs. distributed addon repos.
ideas? suggestions? PRs?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
On Sat, Jul 27, 2019 at 4:59 PM Helmut Kudrnovsky <hellik@web.de> wrote:
hi,
addons isn’t working, see e.g.
etc.
*grass72
*grass74
base_url = “http://wingrass.fsv.cvut.cz/
“grass%(major)s%(minor)s/%(platform)s/addons/”
“grass-%(major)s.%(minor)s.%(patch)s” %
{‘platform’: platform,
‘major’: version[0], ‘minor’: version[1],
‘patch’: version[2]}
*grass76
*grass77
#‘patch’: version[2]}
‘patch’: ‘svn’}
the same in
#‘patch’: version[2]} # comment this out
‘patch’: ‘svn’} # add this
see e.g.
occur.
  • for the short term, we need a winGRASS addon consolidation and a fix
  • for the long term, buidling winGRASS addon via appveyor (compare e.g.
    deliver them.
So far I have been telling people to use 7.2.3, the only version which seems to work with addons. Martin, any reason why the folder structure changed on the server, even for the stable 7.6 version?
Anna
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
so 27. 7. 2019 v 23:59 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
etc.
would be very surprised when there will be no complaints at all :wink:
That's very unfortunate situation.
WinGRASS builds are broken since May because several reasons:
1) git migration
2) attempt to update building environment (gcc 4.x to newer version)
3) various strange problems with new build environment
4) lack of time to fix all the issues during summer
I am planning to invest some time during FOSS4G 2019 code sprint on
Saturday and most importantly the next week with hope to fix crucial
problems in order to offer builds again. But it's painful experience.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
compiling with the newest msys2 gcc seems to work here.
I have this one here
https://lists.osgeo.org/pipermail/grass-dev/2019-August/093063.html
Do you have a list of your issues facing while winGRASS compiling?
So I could do some Tests here.....
best regards
Helmut
pá 30. 8. 2019 v 17:35 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
different :wink: I am closer to successful build. Now it fails compiling
ctypes/display.py:
Status: Processing description list.
  File "./ctypesgen.py", line 165, in <module>
    ctypesgencore.processor.process(descriptions, options)
  File "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\processor\pipeline.py",
line 60, in process
    find_source_libraries(data, options)
  File "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\processor\operations.py",
line 206, in find_source_libraries
    library = ctypesgencore.libraryloader.load_library(library_name)
  File "C:\msys64\usr\src\grass79\lib\python\ctypes\ctypesgencore\libraryloader.py",
line 258, in load_library
    result = LibraryLoader.load_library(self, libname)
line 63, in load_library
    return self.load(path)
line 279, in load
    return _WindowsLibrary(path)
line 240, in __init__
    self.cdll = ctypes.cdll.LoadLibrary(path)
  File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 434,
in LoadLibrary
    return self._dlltype(name)
  File "C:\OSGeo4W64\apps\Python37\lib\ctypes\__init__.py", line 356,
in __init__
    self._handle = _dlopen(self._name, mode)
OSError: [WinError 127] Uvedená procedura nebyla nalezena
make[6]: *** [Makefile:102: OBJ.x86_64-w64-mingw32/display.py] Error 1
After debuging it turned out, that libgrass_display.7.9.dll cannot be
loaded. It's also reason why d.* modules fails with:
make[4]: Leaving directory '/c/msys64/usr/src/grass79/display/d.barscale'
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/9.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe:
warning: --export-dynamic is not supported for PE+ targets, did you
mean --export-all-symbols?
if [ "/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/d.barscale.exe"
!= "" ] ; then GISRC=/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/scripts:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/c/OSGeo4W64/bin:/c/msys64/usr/src/grass79/mswindows/osgeo4w/lib:/c/msys64/usr/src/grass79/mswindows/osgeo4w:/usr/bin:/mingw64/bin"
LC_ALL=C LANG=C LANGUAGE=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
d.barscale.tmp.html ; fi
make[3]: *** [../../include/Make/Html.make:14: d.barscale.tmp.html] Error 1
Meanwhile I copied this broken build to OSGeo4W environment (on same
PC), all d.* were working, no problem with display dll. I have no
clue...
Thanks! With 7.8.0 released and next QGIS release in few days, the
issue with wingrass builds is more than critical.
Ma
Martin Landa
pá 30. 8. 2019 v 17:35 odesílatel Helmut Kudrnovsky <[hidden email]> napsal:
completly fresh git checkout here, still the already earlier mentioned issue
in
GRASS GIS 7.9.dev a9d2c0bd6 compilation log
Started compilation: Sat Sep 7 11:16:10 CEST 2019
Errors in:
/usr/src/grass_trunk_git/grass/lib/pngdriver
/usr/src/grass_trunk_git/grass/lib/psdriver
caused by
if [ "" != "" ] ; then
GISRC=/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/demolocation/.grassrc79
GISBASE=C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:$PATH"
PYTHONPATH="C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python;C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/gui/wxpython;$PYTHONPATH"
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/c/OSGeo4W64/apps/Python37:/usr/bin:/mingw64/bin/:/c/OSGeo4W64/bin:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w/lib:/usr/src/grass_trunk_git/grass/mswindows/osgeo4w"
LC_ALL=C LANG=C LANGUAGE=C --html-description < /dev/null | grep -v
'</body>\|</html>' > pngdriver.tmp.html ; fi
VERSION_NUMBER=7.9.dev VERSION_DATE=2019 MODULE_TOPDIR=../.. \
        python3
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/tools/mkhtml.py
pngdriver >
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/docs/html/pngdriver.html
Fatal Python error: initfsencoding: unable to load the file system codec
ModuleNotFoundError: No module named 'encodings'
did a pacman -Syu in msys2 for an uptodate python
pacman -Ql mingw-w64-x86_64-python3 > pac.log shows:
mingw-w64-x86_64-python3 /mingw64/lib/python3.7/encodings/
mingw-w64-x86_64-python3 /mingw64/lib/python3.7/encodings/__init__.py
mingw-w64-x86_64-python3 /mingw64/lib/python3.7/encodings/__pycache__/
/mingw64/lib/python3.7/encodings/__pycache__/__init__.cpython-37.opt-1.pyc
package encodings should be there.
maybe an intereference between msys/python3 and osgeo4w/python3
will investigate ...
best regards
Helmut
so 7. 9. 2019 v 11:39 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
this part I already solved locally. Will create WIP PR. I have
different problem with display dll.
I tried to run manually in msys2 bash:
--html-description
I got no output, no error.
When I switched to r.info.exe, it works.
/c/msys64/usr/src/grass79/dist.x86_64-w64-mingw32/bin/r.info.exe
--html-description
Ma
Martin Landa
so 7. 9. 2019 v 12:01 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
https://github.com/OSGeo/grass/pull/126
Martin Landa
napsal:
issue
in
Errors in:
caused by
</body>
</html>
        python3
pngdriver >
msys2:
myuser@DESKTOP-VADT8Q4 MINGW64 /usr/src/grass_trunk_git/grass
$ python --version
Python 3.7.4
$ python3 -c "import encodings; print(encodings.__file__)"
C:/msys64/mingw64/lib/python3.7/encodings/__init__.py
$ python
Python 3.7.4 (default, Aug 15 2019, 18:17:27) [GCC 9.2.0 64 bit (AMD64)] on
win32
Type "help", "copyright", "credits" or "license" for more information.
import encodings
osgeo4w:
C:\>python --version
Python 3.7.0
C:\>python3 -c "import encodings; print(encodings.__file__)"
C:\OSGEO4~1\apps\Python37\lib\encodings\__init__.py
C:\>python
Python 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit
(AMD64)] on win32
import encodings
in package.sh
# Force Python3
# alias python=python3
export PYTHONPATH=
export PYTHONHOME=$OSGEO4W_ROOT_MSYS/apps/Python37
export PATH=$OSGEO4W_ROOT_MSYS/apps/Python37:$PATH
do we use msys2/py3 or osgeo4w/py3 for compilation?
best regards
Helmut
so 7. 9. 2019 v 12:07 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
msys2:
$ python --version
Python 3.7.4
osgeo4w:
Python 3.7.0
it's not good idea to mix different version of Python. By [1] is
forced osgeo4w Python version. In [2] he should remove all python
packages.They are not needed.
Ma
[1] https://github.com/OSGeo/grass/pull/126
[2] https://trac.osgeo.org/grass/wiki/CompileOnWindows#InstalltheMSYS2directorystructure
Martin Landa
it's not easy to keep msys2 and osgeo4w python in sync
By [1] is
does it mean that in msys2 there is no python3 needed at all?
pacman -S [...] mingw-w64-x86_64-python3-numpy mingw-w64-x86_64-python3-six
should this be removed von the how-to-compile wiki?
if I remember I added them when we started to compile with python3 back them
because compilation failed ....
best regards
Helmut
so 7. 9. 2019 v 12:20 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
the goal is to use Python version from osgeo4w environment, see
>By [1] is
I think so. Ma
Martin Landa
Martin Landa wrote
pá 30. 8. 2019 v 17:35 odesílatel Helmut Kudrnovsky &lt;
hellik@
&gt; napsal:
ctypes/display.py:
<module>
  File
line 60, in process
  File
  File
  File
  File
line 279, in load
  File
in LoadLibrary
in __init__
I get a longer log with errors when I'm do make in the ctypes subfolder:
$ make
make
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib
make[1]: Entering directory
'/usr/src/grass_trunk_git/grass/lib/python/ctypes'
make[1]:
'/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib'
is up to date.
make[1]: Leaving directory
make OBJ.x86_64-w64-mingw32/date.py OBJ.x86_64-w64-mingw32/gis.py
OBJ.x86_64-w64-mingw32/raster.py OBJ.x86_64-w64-mingw32/gmath.py
OBJ.x86_64-w64-mingw32/proj.py OBJ.x86_64-w64-mingw32/imagery.py
OBJ.x86_64-w64-mingw32/vector.py OBJ.x86_64-w64-mingw32/rtree.py
OBJ.x86_64-w64-mingw32/display.py OBJ.x86_64-w64-mingw32/stats.py
OBJ.x86_64-w64-mingw32/dbmi.py OBJ.x86_64-w64-mingw32/raster3d.py
OBJ.x86_64-w64-mingw32/arraystats.py OBJ.x86_64-w64-mingw32/cluster.py
OBJ.x86_64-w64-mingw32/vedit.py OBJ.x86_64-w64-mingw32/segment.py
OBJ.x86_64-w64-mingw32/rowio.py OBJ.x86_64-w64-mingw32/temporal.py
OBJ.x86_64-w64-mingw32/ogsf.py OBJ.x86_64-w64-mingw32/nviz.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/date.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gis.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gmath.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/proj.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/imagery.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vector.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rtree.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/display.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/stats.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/dbmi.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster3d.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/arraystats.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/cluster.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vedit.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/segment.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rowio.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/temporal.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ogsf.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/nviz.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/__init__.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_preamble.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_loader.py
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/date.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gis.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/gmath.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/proj.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/imagery.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vector.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rtree.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/display.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/stats.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/dbmi.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/raster3d.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/arraystats.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/cluster.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/vedit.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/segment.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/rowio.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/temporal.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ogsf.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/nviz.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/__init__.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_preamble.pyc
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/etc/python/grass/lib/ctypes_loader.pyc
make[1]: 'OBJ.x86_64-w64-mingw32/date.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/gis.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/raster.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/gmath.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/proj.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/imagery.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/vector.py' is up to date.
make[1]: 'OBJ.x86_64-w64-mingw32/rtree.py' is up to date.
PATH="/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/bin:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/scripts:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/lib:/mingw64/bin:/usr/local/bin:/usr/bin:/bin:/c/Windows/System32:/c/Windows:/c/Windows/System32/Wbem:/c/Windows/System32/WindowsPowerShell/v1.0/:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl"
LC_ALL=C LANG=C LANGUAGE=C ./ctypesgen.py --cpp "gcc -E
-I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-I/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include
-D__GLIBC_HAVE_LONG_LONG" -lgrass_display.7.9
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/display.h
/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/display.h
-o OBJ.x86_64-w64-mingw32/display.py
Status: Preprocessing C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h
Status: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG -U __GNUC__ -dD "-Dinline=" "-D__inline__="
"-D__extension__=" "-D_Bool=uint8_t" "-D__const=const" "-D__asm__(x)="
"-D__asm(x)=" "-DCTYPESGEN=1"
"C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h"
Error: gcc -E -I/c/OSGeo4W64/include -D_FILE_OFFSET_BITS=64
-D__GLIBC_HAVE_LONG_LONG: In file included from
C:/msys64/mingw64/x86_64-w64-mingw32/include/_mingw.h:284,
-D__GLIBC_HAVE_LONG_LONG: from
C:/msys64/mingw64/x86_64-w64-mingw32/include/corecrt.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/crtdefs.h:10,
C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:9,
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/gis.h:24,
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/display.h:4,
C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h:1:
C:/msys64/mingw64/x86_64-w64-mingw32/include/vadefs.h:35:2: error: #error
VARARGS not implemented for this compiler
-D__GLIBC_HAVE_LONG_LONG: 35 | #error VARARGS not implemented for this
compiler
-D__GLIBC_HAVE_LONG_LONG: | ^~~~~
Status: Parsing C:/Users/hkmyr/AppData/Local/Temp/tmpr1ty7l93.h
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/corecrt.h:80: Syntax
error at 'uintptr_t'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:165: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:171: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:177: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:182: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:191: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:197: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:203: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:209: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:512: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:514: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:516: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:535: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:537: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:539: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:732: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:765: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:770: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:772: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:806: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:818: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:822: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:826: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:833: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:835: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:839: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:843: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1060: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1061: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1062: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1088: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1089: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1183: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1185: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1186: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1196: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1201: Syntax
error at 'argp'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1208: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1210: Syntax
error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/stdio.h:1218: Syntax
error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:475:
Syntax error at 'va_list'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:484:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:485:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:487:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:489:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:491:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:500:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:501:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:502:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:504:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:507:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:508:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:511:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:512:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:515:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:516:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:519:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:520:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:522:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:524:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:526:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:528:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:531:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:532:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:739:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:740:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:742:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:746:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:752:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:754:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:756:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:758:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:781:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:782:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:784:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:786:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:789:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:790:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:793:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:794:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:797:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:798:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:801:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:803:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:805:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/stdio_s.h:806:
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:40:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:71:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:73:
Syntax error at ';'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:78:
Syntax error at '{'
Error: C:/msys64/mingw64/x86_64-w64-mingw32/include/sec_api/string_s.h:79:
Syntax error at ':'
Error:
C:/msys64/usr/src/grass_trunk_git/grass/dist.x86_64-w64-mingw32/include/grass/defs/gis.h:157:
  File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\pipeline.py",
line 60, in process
  File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\processor\operations.py",
  File
"C:\msys64\usr\src\grass_trunk_git\grass\lib\python\ctypes\ctypesgencore\libraryloader.py",
  File
  File
line 279, in load
  File
  File "C:/msys64/mingw64/lib/python3.7\ctypes\__init__.py", line 442, in
LoadLibrary
  File "C:/msys64/mingw64/lib/python3.7\ctypes\__init__.py", line 364, in
__init__
OSError: [WinError 126] Das angegebene Modul wurde nicht gefunden
make[1]: *** [Makefile:102: OBJ.x86_64-w64-mingw32/display.py] Error 1
make: *** [Makefile:81: default] Error 2
best regards
Helmut
compiler
$ gcc --version
gcc.exe (Rev2, Built by MSYS2 project) 9.2.0
Copyright (C) 2019 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
best regards
Helmut
compiler
$ gcc --version
PURPOSE.
regarding
error at 'va_list'
and ctypes issue see also:
https://trac.osgeo.org/grass/ticket/3368
best regards
Helmut
regarding
error at 'va_list'
https://docs.microsoft.com/en-us/cpp/c-runtime-library/reference/va-arg-va-copy-va-end-va-start?view=vs-2019
best regards
Helmut
so 7. 9. 2019 v 13:06 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
  File
line 60, in process
  File
  File
  File
  File
line 279, in load
  File
LoadLibrary
__init__
so apparently you have the same problem as me. It fails to load
libgrass_display.7.9.dll for unknown reason. It also causes that all
display modules fails to be compiled (or at least manual pages are not
generated).
Ma
so 7. 9. 2019 v 13:28 odesílatel Helmut Kudrnovsky <hellik@web.de> napsal:
> error at 'va_list'
it would be nice of course to solve these error. In any case these
errors do not cause compilation failure.
Ma
Martin Landa
Martin Landa wrote
so 7. 9. 2019 v 13:28 odesílatel Helmut Kudrnovsky &lt;
hellik@
&gt; napsal:
Syntax
> error at 'va_list'
Ma
Martin Landa
grass-dev@.osgeo
What about this one in display:
best regards
Helmut
Hi Helmut,
so 7. 9. 2019 v 20:31 odesílatel Martin Landa <landa.martin@gmail.com> napsal:
generated).
try to run from msys terminal (or something similar depending on your paths):
--html-description
You will probably do not get any output or even error (which is problem).
But when you run the same command for r.info.exe, it works.
--html-description
Ma
Martin Landa
