Hi Martin,
Martin Landa wrote
I have recovered (at least partially) wingrass builds:
* daily builds (GRASS 7.6 & 7.7: only 64bit builds) [standalone [1] &
osgeo4w/grass-daily) are operational
Up-to-date maintenance scripts available at [2].
In next days I will re-cover grass74 daily builds and more importantly
release addons builds (7.4.4 & 7.6.1).
thanks for your effort to bring winGRASS daily builds back
tested here with the OSGeo4W 64bit dailys.
following issue when downloading OSGeo4W grass-daily-7.7.dev-f79c3568d-1:
° g.mkfontcap.exe - system error because libgraphite2.dll and libpcre-1.dll
can't be found
° "inflateValidate" in the dll
C:\OSGeo4W\apps\grass\grass77\bin\libpng16-16.dll can't be found
regarding the last issue item, in C:\OSGeo4W\apps\grass\grass77\bin\ there
shouldn't be any foreign dll, right?
looking into it
C:\OSGeo4W64\apps\grass\grass77\bin>ls | grep lib
libbz2-1.dll
libexpat-1.dll
libfontconfig-1.dll
libfreetype-6.dll
libgcc_s_seh-1.dll
libglib-2.0-0.dll
libharfbuzz-0.dll
libiconv-2.dll
libintl-8.dll
libpng16-16.dll
libstdc++-6.dll
libsystre-0.dll
libtre-5.dll
libwinpthread-1.dll
test.raster3d.lib.exe
zlib1.dll
downloading
https://wingrass.fsv.cvut.cz/grass77/x86_64/osgeo4w/grass-daily-7.7.dev-f79c3568d-1.tar.bz2
D:\temp\wwf\grass-daily-7.7.dev-f79c3568d-1.tar\grass-daily-7.7.dev-f79c3568d-1\apps\grass\grass77\bin>ls
| grep lib
libbz2-1.dll
libexpat-1.dll
libfontconfig-1.dll
libfreetype-6.dll
libgcc_s_seh-1.dll
libglib-2.0-0.dll
libharfbuzz-0.dll
libiconv-2.dll
libintl-8.dll
libpng16-16.dll
libstdc++-6.dll
libsystre-0.dll
libtre-5.dll
libwinpthread-1.dll
zlib1.dll
these dlls are in
any idea about that?
these dlls maybe are the reason for
Starting GRASS GIS...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
nicht möglich.
Cleaning up temporary files...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS GIS 7.7.dev
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.18362.175]
(c) 2019 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>C:\OSGEO4~1\apps\grass\grass77\gui\wxpython\wxgui.py:101:
DeprecationWarning: Yield() is deprecated
wx.Yield()
GRASS Modul 'g.proj' nicht gefunden. Kann Kartenfenster nicht starten.
Error in atexit._run_exitfuncs:
wx._core.wxAssertionError: C++ assertion "GetEventHandler() == this" failed
at ..\..\src\common\wincmn.cpp(478) in wxWindowBase::~wxWindowBase(): any
pushed event handlers must have been removed
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
