Would there be interest to have in the wxGUI the possibility to change
the current working directory for a GRASS session? By default this is
under windows the documents and settings folder of the current user,
but project-related data and output may well be somewhere else. This
"somewhere else" could be made the current working directory as far as
the wxGUI is concerned (similar to what R has for windows). I have a
patch to do that in the wxGUI in my local copy and would like to know
if there is general interest in this little patch.
Markus M
it would be great to have that - it would make it much easier to manage homework results for all the students using GRASS in class, especially when they are just starting,
Helena
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
Added in trunk r50167. Save the user-defined current working directory
in a GRASS environment variable?
Markus M
Helena
Markus M
