[GRASS-dev] winGRASS compilation: perl not found (needed for MAN)
we try to compile winGRASS on a colleague's computer (XP),
following
https://trac.osgeo.org/grass/wiki/CompileOnWindows
./mswindows/osgeo4w/package.sh
checking for perl... no
At this point, MAN is not created, leading to a tar packaging error later.
But:
$ perl -v
This is perl., v5.10.1 built for MSWin32-x86-multi-thread
I am suprised that perl isn't detected by configure. Nothing dramatic of course.
Did any other winGRASS builder observe this problem?
On Tue, Jan 19, 2010 at 5:26 AM, Markus Neteler <neteler@osgeo.org> wrote:
following
But:
$ perl -v
Forgot to mention that we installed Perl from ActiveState as in OSGeo4W
we couldn't (surprisingly) find it.
following
But:
$ perl -v
dramatic of course.
No idea why; it's just an AC_PATH_PROG() check; nothing unusual about
it.
I've never noticed it, because man/Makefile silently skips building
the manpages if Perl isn't present (I don't have it on Windows).
Maybe we should use the Python version from 7.0? Many users will want
Python anyhow, whereas Perl is only used for g.html2man.
OTOH, how many Windows users will want nroff manpages?
On Tue, Jan 19, 2010 at 7:20 AM, Glynn Clements
following
But:
$ perl -v
dramatic of course.
it.
That's right but "tar" complains (read: warns) about the missing man
stuff later. Perhaps it has to be conditionalized upon perl presence
as well.
Sounds good, we would get rid of a dependency.
Likely 0.001%. It was more for a potential breakage of the packaging
process.
will want Python anyhow, whereas Perl is only used for
g.html2man.
At this point, my vote, AFA 6.4.0 goes, is to follow the path of
least change. Which is to keep the existing perl script.
or even know how to access them?
Hamish
as well.
It's better to test what's actually required (i.e. the presence of the
dist.<arch>/man directory).
g.html2man.py shouldn't have any actual dependencies of its own.
However, I did have to clean up quite a few files in 7.0 to get the
parser to accept them (it's an actual HTML parser, and not
particularly fault-tolerant; the Perl version is just regexp
search/replace, so it might fail but it won't complain).
process.
Then it's probably beter to just modify the packager.
2010/1/19 Hamish <hamish_b@yahoo.com>:
g.html2man.
OK, anyway I would vote to replace Perl script in 6.5.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Tue, Jan 19, 2010 at 12:29 PM, Martin Landa <landa.martin@gmail.com> wrote:
g.html2man.
Agreed - we may then backport to 6.4.1 if possible and stable.
g.html2man.
Hamish:
path of least change. Which is to keep the existing perl
script.
Martin:
Markus:
actually now that I think about it, this is much more of a
shift in policy and I'm not sure if we should think about it
for 6.5 either.
Remember that currently python is not a mandatory build dep for
GRASS 6.x.
Also AFAIK python does not come preinstalled on e.g. debian as
a base package, but perl does.
So we are making python a mandatory build dep for ... getting
man(1) pages working on MS Windows ?? seems very dis-
proportionate to me.
Hamish
g.html2man.
Martin:
for 6.5 either.
GRASS 6.x.
Good point.
Well, but Debian is not the gold standard (sorry). On other systems
it does.
I darkly remember a new GUI :slight_smile:
But I agree that Python is not a mandatory build dep for GRASS 6.x.
>>>> g.html2man.
Hamish:
>>> script.
Martin:
Markus:
for 6.5 either.
GRASS 6.x.
Why is making a Python a mandatory build dependency worse than making
Perl a mandatory build dependency? At least Python is useful for other
things, while Perl is *only* used for g.html2man.
As for the merits of the two versions of g.html2man: the Python
version can handle tables, although the Perl version has the advantage
that it can't fail (it may produce garbage, but AFAICT it will produce
*something* so long as the input file exists).
IMHO, the main reason to stick with the Perl version isn't down to
which language to make a required dependency, but the effort required
to clean up the 6.x manpages.
On Wed, Jan 20, 2010 at 6:15 AM, Glynn Clements
If the Python version would be backported to 6.5, I could walk through the
HTML pages, fix them and backport the HTML bugfixes to 6.4. They should
be done in any case...
Back-porting is just a matter of copying g.html2man.py from 7.0 and
changing HTML2MAN in man/Makefile (remove the "sh").
Trying this, I get errors in 66 files, while 416 build without error.
If parsing fails, g.html2man.py will display the line number and the
line, but won't describe the error (most of them are due to using
block-level elements as if they were inline; using blocks inside
<dt>...</dt> is a common flaw).
There is some useful information on validation at:
http://grass.osgeo.org/wiki/Updating_GRASS_Documentation#A_brief_guide_to_valid_HTML
On Wed, Jan 20, 2010 at 12:16 PM, Glynn Clements
[and add the .py extension of course]
I have reduced it to these errors here:
htmlmapdriver.html:63
wxGUI.html:154
wxGUI.Vector_Digitizing_Tool.html:210
Those are tricky <dd> issues (too tired now),
wxGUI.html:154
thanks,
yeah, and https://trac.osgeo.org/grass/ticket/612
(r37877 never got backported (or foreported) btw; I'm not much
of a fan of the perl version but am not being a stick in the mud
about keeping it without having been here before...)
just one last repeat of the python vs. perl dep: you can expect
to find a usable perl on any linux distro >100mb.
It is much more mature than python so you don't have to worry
about installed version much (if at all), and [as far as linux
goes anyway, and I expect OSX too] you can be pretty confident
that it will already be installed and work regardless of distro
& setup. It will be many years before you can expect the same
stability from python (esp. with 3.0+ coming) so it is less to
maintain in the long term for a branch we don't want to touch.
I will concede that for 6.5+ the default GUI is wxpy, so it is
not unreasonable to expect to find python there.
regards,
Hamish
wxGUI.html:154
Simple suggestion for 6.4: Since the backport of the Python version is
trivial, why not have both converters in Perl and Python?
Use Perl as default and, if missing, try the Python version.
>> wxGUI.html:154
I'd suggest the other way around. The Python version can handle
tables, the Perl version can't. That's why I wrote the Python version
in the first place.
Markus:
seems like too much double handling to me. just pick whichever one and go
with it. sorting the rest out as needed is probably less work than trying
to get the two to work in parallel.
Hamish
