[GRASS-dev] winGRASS: enabling non-english languages?
On Tue, Jan 19, 2010 at 12:43 AM, Markus Neteler <neteler@osgeo.org> wrote:
On Sat, Jan 16, 2010 at 6:42 AM, Glynn Clements
<glynn@gclements.plus.com> wrote:
Markus:
The point is that translations should be enabled
also for CMD line usage which requires as far as I understand a change
in Init.bat (?).
On Windows, Init.bat should set LANG (or at least LC_MESSAGES and
LC_CTYPE). But LANG needs to be in Unix format (e.g. "ja_JP"), while
Windows provides a numeric code. So we need some way to get the
appropriate LANG value from the Windows locale setting.
Thanks for r40533 which I have backported to 6.4 (r40540) and 6.5 (r40539).
When launching latest winGRASS-SVN (self compiled) in the MinGW shell,
the LANG and LC_MESSAGES are not set.
Do we need a similar change in Init.sh for MinGW?
MinGW shell, the LANG and LC_MESSAGES are not set.
note that mswindows/GRASS-Installer.nsi dynamically creates both
.sh and .bat launchers which may need adjustment.
Hamish
>>> in Init.bat (?).
Hmm; MSys[1] users should be setting LANG (etc) in ~/.bash_profile
(etc) if they want it set.
[1] MinGW is gcc + binutils; MSys is the bash shell and common
utilities.
I think that we should avoid pointing Windows users towards MSys, lest
the mailing list turns into a "bash-help" or "unix-help" list.
I'm starting to regret that we didn't decide to move all of the
scripts to Python for 6.4.
the scripts to Python for 6.4.
I don't at all. Let's ship 6.4 and move dev focus to grass 7
instead of trying to turn grass 6.x into grass 7.x. WinGrass
may be a bit bumpy before we get there, but so be it.
Hamish
