Moritz Lennert wrote:
>> The grass-6.3.cvs/etc/fontcap file in wingrass contains a series of
>> entries of the sorts:
>> cyrilc|Cyrillic|0|c:\grasssrc\grass6\dist.i686-pc-mingw32\fonts\cyrilc.hmp|0|utf-8|
>> This should be
>> cyrilc|Cyrillic|0|c:\grass\grass-6.3.cvs\fonts\cyrilc.hmp|0|utf-8|
>> IIUC, the line that deals with this in the Makefile is (277):
>> -sed 's#'${GISBASE}'#'${INST_DIR}'#g' ${GISBASE}/etc/fontcap >
>> ${INST_DIR}/etc/fontcap
>> Do we need an equivalent line for wingrass with WINGISBASE ?
> WINGISBASE doesn't exist during compilation. AFAICT, it's only used
> within grass63.bat and init.bat.
Duh, obviously it has nothing to do with WINGISBASE. The problem is path
syntax:
content of dist.i686-pc-mingw32/etc/fontcap:
cyrilc|Cyrillic|0|c:\grasssrc\grass-6.3.0RC1\dist.i686-pc-mingw32\fonts\cyrilc.h
mp|0|utf-8|
It's sort of related to WINGISBASE; if you run the installation
in-place, WINGISBASE would be set to:
which would work. But WINGISBASE isn't set while building, only when
actually running GRASS.
sed command in the Makefile:
which during install translates to
sed
's#'/c/grasssrc/grass-6.3.0RC1/dist.i686-pc-mingw32'#'c:/grass63RC1/grass-6.3.0RC1'#g'
/c/grasssrc/grass-6.3.0RC1/dist.i686-pc-mingw32/etc/fontcap >
c:/grass63RC1/grass-6.3.0RC1/etc/fontcap
fontcap entries need to use windows syntax under windows for gis.m to see
the font.
It's more than just gis.m; C functions (e.g. fopen()) only understand
Windows syntax, not MinGW/MSys syntax. Forward slashes work in most
places (but not in the command interpreter), so either c:/grass63RC1
or c:\grass63RC1 will work, but /c/grass63RC1 won't.
So, we need a specific sed command for windows, but do we have a variable
for GISBASE in windows path syntax ? If not how to create it ?
> Or, you can always regenerate the fontcap file after installation.
That's what I'm doing manually now for the binaries, but it would be great
to have this to happen automatically. Is this possible in the Makefile ?
g.dirseps will convert the separators, but not the /c/ -> c:/ for the
drive letter.
Does $(RUN_GISBASE) have the correct syntax?
