[GRASS-dev] winGRASS: 'g.gui wxpython' fails when installed in "Program Files"
(separating this from locale-related email exchange)
With winGRASS is installed in "Program Files", g.gui wxpython
bails out with this error:
GRASS 6.4.0svn (demolocation)> g.gui wxpython
wxgui: can't open file 'C:/Program': [Errno 2] No such file or directory
Comments:
On Thu, Jan 14, 2010 at 1:22 AM, Glynn Clements
<glynn@gclements.plus.com> wrote:
Glynn Clements wrote:
> > Even if we continue to use _spawn*, the quoting code can be taken from
> > 7.0; see escaped() in lib/gis/spawn.c. The code is actually quite
> > tricky, due to the bizarre quoting rules:
> > http://msdn.microsoft.com/en-us/library/17w5ykft.aspx
> Would it be possible for you to suggest a patch?
I'll look into it.
Copying spawn.c from 7.0 seems to work fine. But it's a significant
change, so it should be tested as thoroughly as possible.
Could a developer who has the compile train running, please test this?
Also, fixing
G_spawn() doesn't help with modules which use system() or popen(); I
quite recently replaced most of those in 7.0.
BTW: in looking for test cases, I noticed that neither "g.list -f" nor
"g.mlist -f" work on Windows. E.g.:
sprintf(lister, "%s/etc/lister/%s", G_gisbase(),
list[n].element[0]);
if (access(lister, 1) == 0) { /* execute permission? */
G_spawn(lister, lister, opt.mapset->answer, NULL);
continue;
Because the path lacks the .exe suffix, the access() call fails.
G_spawn() itself doesn't need the .exe suffix, but it never gets that
far.
On Thu, Jan 14, 2010 at 7:41 AM, Glynn Clements
> far.
Would this be hell?
#ifndef __MINGW32__
#else
    sprintf(lister, "%s/etc/lister.exe/%s", G_gisbase(),
#endif
The .exe goes on the end:
#ifndef __MINGW32__
#else
   sprintf(lister, "%s/etc/lister/%s.exe", G_gisbase(),
#endif
Except ... this requires that the lister is an executable; there's no
fundamental reason why it couldn't be a script, other than the
access() check (well: that, and the fact that G_spawn() etc don't use
the shell currently).
Is that a +/-0 or a -1 for the second patch?
>> Would this be hell?
>> #ifndef __MINGW32__
>> #else
>> #endif
> #ifndef __MINGW32__
> #else
> #endif
I'd say +1. Having it only work with a .exe is preferable to it not
working at all.
wxpython bails out with this error:
or directory
try with DEBUG=3
Hamish
or directory
try with DEBUG=3
I think I did but it didn't report anything. Glynn suggested to
substitute spawn.c with the version from GRASS 7.
>> or directory
> try with DEBUG=3
I've fixed another issue with spawn.c in 7.0 and copied it to 6.5 (not
6.4 yet). I've tested 6.5 on Windows and "g.gui wxpython" works with
spaces in %GISBASE% and/or %GRASS_PYTHON% (all four combinations were
tested).
On Tue, Jan 19, 2010 at 12:26 PM, Glynn Clements
>> or directory
> try with DEBUG=3
tested).
For the record: backported to 6.4 and it works as well.
