I tried the installer on a windows 7 virtual box machine,
it install fine without errors, also the automatic sperfish download works fine.
i tried just to load some files,
nviz works with tcltk (no in python) while vdigit don't works.
i had not to much time to test it, but if you point me to a script to beused as "unit test" maybe based on spearfish, i'll be appy to try it.
let me know if you need to test a precise instruction.
regards,
Massimo.
Il giorno 21/dic/2009, alle ore 13.18, Hamish ha scritto:
Modified: grass-web/trunk/grass64/binary/mswindows/index.html
+<li><I> For Windows XP and Vista, 32 and 64 bit</I> <!-- how about Win7?-->
the NSIS used for packaging the self-installer should
be Win7-aware, but I have no Win7-box for testing the
installer.
ok. we will wait for a report of a positive experience before claiming that
we support it.
nviz works with tcltk (no in python) while vdigit don’t works.
i had not to much time to test it, but if you point me to a script to beused as “unit test” maybe based on spearfish, i’ll be appy to try it.
