it seems there is an issue with winGRASS:
32 bit:
https://wingrass.fsv.cvut.cz/grass73/x86/logs/log-r71641-1/error.log
GRASS GIS 7.3.svn r71641 compilation log
Started compilation: Tue Nov 7 21:30:33 2017
Errors in:
/c/msys32/usr/src/grass_trunk/raster/r.in.gdal
In case of errors please change into the directory with error and run
'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Tue Nov 7 22:05:34 2017
64bit:
last build:
WinGRASS-7.3.svn-r71641-404-Setup-x86_64.exe 08-Nov-2017 07:46 73M
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
