neteler
December 27, 2015, 10:24pm
1
while teaching our IRSAE course
(http://gis.cri.fmach.it/grass-gis-and-r-course/ ) we did not have
success to perform a NVIZ exercise on Windows.
Switching to 3D mode leads to a GUI crash when loading the "elevation"
DEM. We used "elevation" in the new (yet to be improved) Piemont
location [1].
No error message shown, just crash.
If anyone wants to test:
wget http://geodati.fmach.it/gfoss_geodata/grassdata_course_version1.7z
# unpack (7a is contained eg in p7zip-plugins package):
7z x grassdata_course_version1.7z
--> grassdata_piemonte/user1
Note: It is a new issue since 7.0.1, in 7.0.0 which is installed on
the same machine no such issue.
I suspect that it is the elevation map size causing the issue since
the DEM is larger than that of the NC dataset.
[1] https://trac.osgeo.org/grass/wiki/SampleDataset/Italy/Piemont
hellik
December 28, 2015, 9:25am
2
Markus Neteler wrote
location [1].
I confirm this. in large regions, 3D view crashes.
tested here with
System Info
GRASS Version: 7.0.2
and
System Info
GRASS Version: 7.1.svn
and the piemonte data set (but also with other large rasters):
g.region -p -a raster=elevation@PERMANENT align=elevation@PERMANENT
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5146000
south: 4879500
west: 313000
east: 517000
nsres: 25
ewres: 25
rows: 10660
cols: 8160
cells: 86985600
attached a debug=3 output ( wxnviz_debug.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5243063/wxnviz_debug.txt> ; )
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/winGRASS-OSGeo4W-crashes-when-switching-to-3D-view-tp5243039p5243063.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
it crashes because it can’t allocate enough memory. There must be some limit given by the operating system how much memory it can allocate (altogether and by chunks). I assume the 64-bit version could help with this.
If you run
m.nviz.image elevation_map=elevation output=xxx format=ppm size=640,480
with large regions, you will get:
Loading raster map elevation@PERMANENT …
Current region rows: 13500, cols: 15000
ERROR: G_malloc: unable to allocate 810000000 bytes of memory
Anna
Switching to 3D mode leads to a GUI crash when loading the “elevation”
DEM. We used “elevation” in the new (yet to be improved) Piemont
location [1].
→ grassdata_piemonte/user1
tested here with
System Info
and
System Info
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5146000
south: 4879500
west: 313000
east: 517000
nsres: 25
ewres: 25
rows: 10660
cols: 8160
cells: 86985600
<http://osgeo-org.1560.x6.nabble.com/file/n5243063/wxnviz_debug.txt > )
best regards
Helmut
Sent from the Grass - Dev mailing list archive at Nabble.com .
grass-dev mailing list
grass-dev@lists.osgeo.org
