[GRASS-dev] winGRASS: PATHEXT question
when working with CLI (sh.exe) in winGRASS7, I am able to launch C-modules, eg.
r.buffer2
but not a python script
r.buffer -> command not found
The user has to type
r.buffer.py
I have checked $PATHEXT which contains beside EXE also PY extension.
The problem is that sh.exe ignores PATHEXT, right?
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
r.buffer2
r.buffer.py
also PY extension.
I'm pretty sure that is correct, PATHEXT is only
recognized by DOS & cmd.exe
if sh.exe (bash) does too it will only be because
the MinGW folks have added custom support for it.
but I would guess that they won't have done that.
Hamish
> also PY extension.
Right. But note that "cmd.exe" doesn't just mean running cmd.exe
interactively in a console window, but also C's system() and popen(),
Python's subprocess.Popen(), Windows' ShellExecute(), etc.
If the .py extension is removed, bash will still recognise it as a
script via the shebang, but native Windows APIs won't be able to
execute it.
2011/12/4 Glynn Clements <glynn@gclements.plus.com>:
> also PY extension.
execute it.
I was thinking rather to "hide" the extensions, similarly to
exe-files. In other words, when you type in console window
r.buffer
the python script `r.buffer.py` will be launched. The user doesn't
care if the module is an exe-file or python-script. Probably BAT
script could help(?)
Martin
> execute it.
r.buffer
Only if MSys does some "magic" for BAT; Only EXE gets special
treatment from the OS. Specifically, if CreateProcess() is passed a
command line without a program, the first token in the command line is
taken as the program name. If the program name doesn't have an
extension, ".exe" is appended automatically. Any other extension (e.g.
.bat or .com) must be given explicitly. It's the shell (i.e. cmd.exe)
which uses PATHEXT to search for files with other extensions.
In any case, GRASS itself should be designed around the native
interfaces; on Windows, that means cmd.exe. Any support for MSys
should be done so as not to interfere with that. One option would be
to use shell aliases for scripts, i.e. "alias r.buffer=r.buffer.py".
Another would be to install shell scripts which execute the Python
script with its extension (i.e. the opposite of what we do for shell
scripts in 6.x).
hi,
eg.
r.buffer2
r.buffer.py
some more here in
http://trac.osgeo.org/grass/ticket/1101
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/winGRASS-PATHEXT-question-tp7058942p7064564.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
[...] Probably BAT
see also thread around
http://osgeo-org.1803224.n2.nabble.com/WinGrass6-5-svn-installer-with-selected-addons-td6873977.html#a6918034
i tested manually created bat-wrappers for py-scripts, it seems to work.
Helmut
View this message in context: http://osgeo-org.1803224.n2.nabble.com/winGRASS-PATHEXT-question-tp7058942p7064609.html
