Here you go:
this one taken from 2.8.4.
But I really do not expect any major difference.
Just adjust the version number in the script ...
Ben
marco.pasetti@alice.it wrote:
Hi Michael,
>maybe try and snatch a copy of the wx-config script
>from a Linux install, then just edit the variables in there
>to fit your MinGW/MSYS setup?
yes! it could be a perfect soultion
at the moment I suspended the wxWidgets support task for better times (I read the documentation... too much work and uncertain solutions for the moment...)
If the Linux script will woork ... good! otherwise I will delay the task.
is there anyone outhere that could send me a linux wx-config script please? wxPython version is 2.8.7.1
Many thanks,
Marco
*Da:* grass-dev-bounces@lists.osgeo.org per conto di Benjamin Ducke
*Inviato:* gio 12/06/2008 13.24
*Cc:* grass-dev@lists.osgeo.org
*Oggetto:* Re: R: [GRASS-dev] WinGRASS Plans
Confirmed: no wx-config script in the Windows bin package
However, before you go through the pain of building the whole
thing with MinGW: maybe try and snatch a copy of the wx-config script
Ben
> Hi Michael,
> > >Maybe this is what you have in mind, but I think that the wx-config is
> only
> >needed for compiling vdigit, not for using it. Also, I'm pretty sure
> that if
> >you install the Windows dev package, it has wx-config.
> > I downloaded the Windows dev package, but unfortunately it doesn't
> contain the wx-config file; maybe because it has been built using MS
> Visual C++. I think I'll need to build wxPython from source using MinGW
> to have the wx-config file and, thus, build the new GRASS v.digit.
> > I'll let you know.
> > Regards,
> > Marco
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel: +44 (0)1865 263 800 (switchboard)
Tel: +44 (0)1865 980 758 (direct)
Fax :+44 (0)1865 793 496
benjamin.ducke@oxfordarch.co.uk
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info/> for more information.
Benjamin Ducke
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
(attachments)
wx-config (41.1 KB)
