[GRASS-dev] wingrass - python 2.7
today I published first winGRASS builds compiled with python 2.7 and
wxPython 2.8.12.1 which has been recently introduced in OSGeo4W
framework. I have also changed a little bit extended OSGeo4W framework
for compiling GRASS. MinGW/MSys addons [1] are now copied into
`apps/msys/` [2, 3].
I would like to ask you to test winGRASS (standalone/osgeo4w),
especially daily builds for `grass64` (due to upcoming 6.4.2 release).
Thanks, Martin
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows?version=204#InstalltheenvironmentforcompilationMingW
[2] https://trac.osgeo.org/grass/changeset/50417
[3] https://trac.osgeo.org/grass/wiki/CompileOnWindows?action=diff&version=204
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin,
see
does this mean that I have to reorganize my etablished and working
wingrass-build-environment?
can you please elaborate the rationale behind this change a little bit?
thanks and best regards
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/wingrass-python-2-7-tp4336663p4336735.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
2012/1/24 Helmut Kudrnovsky <hellik@web.de>:
unfortunately yes.
All installed extension [1,2] are msys related not related to
`osgeo4w` framework itself, so they should go to `apps/msys` rather to
the the osgeo4w root directory. This make things more clear.
Martin
[1] http://trac.osgeo.org/grass/wiki/CompileOnWindows#InstalltheenvironmentforcompilationMingW
[2] http://trac.osgeo.org/grass/wiki/CompileOnWindows#Pre-builtBinaries
