[GRASS-dev] winGrass python scripts and grass.py
Markus asked me to post about a fix required for winGrass. Glynn fixed
this issue with grass 7 failing to compile scripts
<http://lists.osgeo.org/pipermail/grass-dev/2009-January/041837.html&gt;
At line 208 of etc/python/grass.py "g.parser" had to be changed to
"g.parser.exe" on windows.
While this is still affecting compiles of trunk
<http://trac.osgeo.org/grass/wiki/CompileOnWindows#Grass-7.0.svntrunk&gt;,
it also appears to be an issue with develbranch_6 for the python
scripts that have been added: v.type.py and g.change.gui.py.
Making the change fixes the problem in the shell (g.change.gui.py
--interface-description) but not in the GUI itself.
Should I open a ticket?
-Colin
