I've just installed the daily wingrass build for r40683 to C:\Program Files\.
I notice in C:\Program Files\GRASS-64-SVN\msys\ the grass start scripts
there are "grass70.sh, grass70.bat, and grass70. grep doesn't see any
sign of "70" in the mswindows/ dir of the source. ?!
unclean build environment?
Vector -> Develop -> Change Types (v.type_wrapper.sh) fails when you
try to [Run] the command.
the error is:
/c/Program: Files/GRASS-64-SVN/msys/bin/sh: No such file or directory
something thinks /c/Program is the drive name I guess?
Same error message with a normal shell script (v.in.gpsbabel)
Also (maybe related), msys.bat needs "%WD%" path name quoted in a number
of places. (an error flashes by in the DOS box about one of them)
msys.bat patch from:
https://trac.osgeo.org/grass/ticket/629
https://trac.osgeo.org/grass/ticket/759
I had thought Colin was applying something like that patch, but I don't
see anything about it now from the liked wiki page:
https://trac.osgeo.org/grass/ticket/811#comment:4
http://trac.osgeo.org/grass/wiki/CompileOnWindows#InstalltheenvironmentforcompilationMingW
maybe it got lost along the way?
Hamish
