[GRASS-dev] winGRASS RC5 Fails on Creating a New Projection
From startpanel, define new location with epsg codes
Used 4326 for WGS84
Returned the following message:
g.proj returned the following informational message: child killed: SIGABRT
Why?
Thanks
Marco
Hi Markus,
I tried to use g.proj from command line and it doesn’t report errors… but reopening GRASS I don’t have the new location!
I should better learn GRASS :wink:
I’ll retry later, now I have to recompile GRASS with the new built (not installed) Tcl version;
About that, I’m still confused about the release: Paul tells (and I trust him) that 8.15 is OK, while recently on the list I found lots of messages telling that it has problem with latest GRASS release.
What do you think about?
Marco
Da: neteler.osgeo@gmail.com per conto di Markus Neteler
Inviato: dom 02/03/2008 1.10
A: marco.pasetti@alice.it
Oggetto: Re: [GRASS-dev] winGRASS RC5 Fails on Creating a New Projection
Hi Marco,
could you try the same on command line?
On Sat, Mar 1, 2008 at 6:59 PM, Marco Pasetti marco.pasetti@alice.it wrote:
Used 4326 for WGS84
Why?
Thanks
Marco
grass-dev mailing list
grass-dev@lists.osgeo.org
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
