[GRASS-dev] winGRASS Self Installer Package
Consider adding bc.exe from http://gnuwin32.sourceforge.net/packages.htm.
This is the bash calculator, which appears to work fine when run under msys.
Jerry
---- Original message ----
Date: Thu, 6 Mar 2008 15:48:05 +0100
Subject: [GRASS-dev] winGRASS Self Installer Package
To: "Benjamin Ducke" <benjamin.ducke@ufg.uni-kiel.de>
Cc: grass-dev@lists.osgeo.org
  Hi Benjamin,
  I'm afraid, but I cannot find the thread...
  I'm very close to finish the installer; these my
  questions:
  1) name diplayed in the installer: GRASS 6.3.0RC5 or
  GRASS 6.3.0RC5 for Windows or simply GRASS 6.3?
  2) MSYS files: I decided to include the whole MSYS
  env, excluding MinGW, obvioulsy; list follows:
  basename.exe
  cut.exe
  false.exe
  id.exe
  ls.exe
  mv.exe
  sed.exe
  tar.exe
  uniq.exe
  bzip2.exe
  date.exe
  find.exe
  info.exe
  m4.exe
  od.exe
  sh.exe
  tee.exe
  vim.exe
  cat.exe
  diff.exe
  fold.exe
  infokey.exe
  make.exe
  patch.exe
  sleep.exe
  texindex.exe
  wc.exe
  chmod.exe
  diff3.exe
  gawk.exe
  install-info.exe
  makeinfo.exe
  ps.exe
  sort.exe
  touch.exe
  xargs.exe
  cmp.exe
  dirname.exe
  grep.exe
  install.exe
  md5sum.exe
  rm.exe
  split.exe
  tr.exe
  comm.exe
  env.exe
  gzip.exe
  less.exe
  mkdir.exe
  rmdir.exe
  stty.exe
  true.exe
  cp.exe
  expr.exe
  head.exe
  ln.exe
  mount.exe
  rxvt.exe
  tail.exe
  uname.exe
  what to keep, what to remove?
  3) bin executables: there are actually some usefull
  apps to add; thi is the list of my /bin exes (I
  built a brand new msys env with grass only needed
  libs):
  XMLTester.exe
  flex.exe
  gdalmanage.exe
  invgeod.exe
  ogrtindex.exe
  tiff2bw.exe
  tiffinfo.exe
  bison.exe
  gdal_contour.exe
  gdaltindex.exe
  invproj.exe
  pal2rgb.exe
  tiff2pdf.exe
  tiffmedian.exe
  bmp2tiff.exe
  gdal_grid.exe
  gdaltransform.exe
  m4.exe
  ppm2tiff.exe
  tiff2ps.exe
  tiffset.exe
  cs2cs.exe
  gdal_rasterize.exe
  gdalwarp.exe
  nad2bin.exe
  proj.exe
  tiff2rgba.exe
  tiffsplit.exe
  fax2ps.exe
  gdal_translate.exe
  geod.exe
  nad2nad.exe
  ras2tiff.exe
  tiffcmp.exe
  fax2tiff.exe
  gdaladdo.exe
  gif2tiff.exe
  nearblack.exe
  raw2tiff.exe
  tiffcp.exe
  fftw-wisdom.exe
  gdalenhance.exe
  gsl-histogram.exe
  ogr2ogr.exe
  rgb2ycbcr.exe
  tiffdither.exe
  flex++.exe
  gdalinfo.exe
  gsl-randist.exe
  ogrinfo.exe
  thumbnail.exe
  tiffdump.exe
  Thanks
  Marco
  Da: grass-dev-bounces@lists.osgeo.org per conto di
  Benjamin Ducke
  Inviato: gio 06/03/2008 15.15
  Oggetto: Re: [GRASS-dev] winGRASS Self Installer
  Package
  I remember dimly that we discussed these things
  before, a few
  weeks back when I was trying to put together a new
  WinGRASS
  distribution. I think that Glynn posted a list of
  useful tools for
  inclusion to this mailing list, back then.
  There are other useful things, such as wget, curl,
  tar, unzip, awk,
  sed, ...
  Some of them may be needed by shell scripts.
  Maybe it would be a good idea to put up a Wikipage
  and start
  adding these things to it?
  Benjamin
  Paul Kelly wrote:
  > On Thu, 6 Mar 2008 marco.pasetti@alice.it wrote:
  >> Hi,
  >>> First of all, I want to express my thanks on
  behalf of students here
  >>> who are using GRASS on Windows [...]
  >> you're welcome... did you already read my new
  GRASS Windows Native
  >> Binary Building Guide?
  http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html
  <http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html&gt;
  >> I'm updating it with packaging instructions
  >> when I'll have enough free time I'll put it into
  GRASS trac
  >>> My suggestion is that you include SQLite but not
  PostgreSQL.[...]
  >> Do you think that libsqlite3-0.dll is enough? in
  my (built) sqlite
  >> directory I have /bin with 1 dll and 1 exe,
  /include with only
  >> includes and /lib dir with static libs.
  > If you've compiled GRASS against the .dll then you
  don't need the static
  > libraries. If you've compiled GRASS against the
  static libraries then
  > you don't need to include anything - the required
  libraries will be
  > statically linked into the GRASS modules (you can
  usually tell this if
  > the size of the binaries is very large. I usually
  delete the static
  > libraries after compiling to make sure they are
  not picked up by
  > accident). You certainly don't need to include the
  header files in
  > include/ for a binary distribution - they are only
  necessary for
  > compiling. If there are some useful utility
  programs in bin/ they may be
  > worth sticking into the GRASS bin directory too,
  e.g. gdalwarp.exe and
  > gdalinfo.exe from GDAL and cs2cs.exe and
  nad2bin.exe from PROJ.
  > For a lot of packages though you just need the DLL
  and can stick it
  > straight into the GRASS $GISBASE/lib directory
  before packaging up the
  > binary distribution.
  > Paul
  > grass-dev mailing list
  > grass-dev@lists.osgeo.org
  > http://lists.osgeo.org/mailman/listinfo/grass-dev
  Benjamin Ducke
  Senior Applications Support and Development Officer
  Oxford Archaeological Unit Limited
  Janus House
  Osney Mead
  OX2 0ES
  Oxford, U.K.
  Tel.: ++44 (0)1865 263 800
  benjamin.ducke@oxfordarch.co.uk
________________
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
