[GRASS-dev] wingrass standalone default options, Microsoft Runtime Libraries
it seems to me that to enable installing Important Microsoft Runtime
Libraries is crucial when installing GRASS using standalone installer
on newer versions of Windows.
I wonder if it would make sense to enable it by default (now it's
uncheck). What do you think? Thanks, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Martin Landa wrote
maybe a better way would be to check if the needed runtime libraries are
already installed?
unfortunately I've never found an easy and feasible way for checking this.
so a +0 for a default install of a Microsoft Runtime Libraries.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass-standalone-default-options-Microsoft-Runtime-Libraries-tp5209586p5209587.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Sun, Jun 7, 2015 at 5:08 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
Martin Landa wrote
> Hi all,
already installed?
I don't understand it much but it seems to me that it always worked only
when they were actually in the GRASS directory. (Although in theory it
should be enough to have them on PATH.)
On Sun, Jun 7, 2015 at 4:58 AM, Martin Landa <landa.martin@gmail.com> wrote:
+1
GNU GPL requires to take positive action (no reference for it now) but
according to the usual practice, I think it would be enough if the check
box would be checked by default and there would be something like don't
proceed if you don't want it (the positive action is pressing Next button).
(If it would be privacy issue or something like that, I would be more
conservative, but this is just fixing operating system defected by design.)
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
2015-06-07 16:42 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
+1
done in r65463. Martin
Martin Landa
2015-06-14 12:52 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
btw, osgeo4w installer is doing the same. Ma
Martin Landa
