[GRASS-dev] WinGRASS temporary down
Dear all,
wingrass.fsv.cvut.cz are temporary down due to server reinstallation.
I will re-enable services ASAP. Thanks for patience, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2017-11-16 18:29 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
wingrass services re-enabled. Let's check if tomorrow's build will be
propagated. Ma
Martin Landa
2017-11-16 23:29 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
propagated. Ma
everything seems to work, see latest build [1]. Maz
[1] https://wingrass.fsv.cvut.cz/grass75/x86/logs/log-r71738-5/error.log
Martin Landa
2017-11-18 19:34 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
I quickly tested 7.5 (64bit), extensions are somehow broken, you are
right. Debug message says:
D1/1: G_set_program_name(): g.message
Downloading precompiled GRASS Addons <d.explanation.plot>...
D1/1: grass.script.core.start_command(): g.message -v
message=Downloading source code for <d.explanation.plot>
from <http://wingrass.fsv.cvut.cz/grass75/x86_64/addons/gras
s-7.5.svn/d.explanation.plot.zip> which is identified as
'remote_zip' type of source...
after re-enabling HTTP on publishing server the winGRASS Addons is
possible to install. The reported issue should be fixed. Ma
Martin Landa
