[GRASS-dev] WinGrass7 - disable LFS
Has disabling LFS to be set explicitly for configure in the windows-world?
I've tried --disable-largefile,
but again there is
checking if system supports Large Files at all... yes
Large File support (LFS): yes
in the build-log.
what have to be done to disable LFS for building WinGrass7?
Helmut
___________________________________________________________
WEB.DE DSL: Internet, Telefon und Entertainment für nur 19,99 EUR/mtl.!
http://produkte.web.de/go/02/
but again there is
in the build-log.
configure.in is broken; it sets USE_LARGEFILES according to whether
LFS is detected, regardless of whether it is enabled. MinGW has LFS,
but it's not in a form which currently works with GRASS.
Von: Glynn Clements <glynn@gclements.plus.com>
but again there is
>in the build-log.
I'm builiding Grass7 on WinVista32. so there shouldn't be LFS?
Helmut
>> but again there is
> >in the build-log.
Configure will detect it, but it doesn't work. GRASS assumes that
defining _FILE_OFFSET_BITS=64 will make off_t a 64-bit type. Windows
has a 64-bit offset type (actually, it has two of them) and functions
which work with it, but you have to use them explicitly; there's no
macro to "redirect" off_t, lseek(), etc to 64-bit versions.
