[GRASS-dev] WinGrass7: starting grass by grass70.py fails
grass7 (r41470) self compiled in the osgeo4w-stack
the osgeo4w-python is Python 2.5.2
opened the osgeo4w-command-line and typed in:
python grass70.py
the starting wx-window of grass is opening and I'm able to choose the location and mapset,
but then following error message comes up:
"Traceback (most recent call last):
File "grass70.py", line 921, in <module>
   check_shell()
File "grass70.py", line 550, in check_shell
sh = os.path.basename(os.getenv('SHELL'))
File "C:\OSGeo4W\apps\Python25\lib\ntpath.py", line 200, in basename
  return split(p)[1]
File "C:\OSGeo4W\apps\Python25\lib\ntpath.py", line 164, in split
  d, p = splitdrive(p)
File "C:\OSGeo4W\apps\Python25\lib\ntpath.py", line 119, in splitdrive
  if p[1:2] == ':':
TypeError: 'NoneType' objects is unsubscriptable
best regards
Helmut
___________________________________________________________
WEB.DE DSL: Internet, Telefon und Entertainment für nur 19,99 EUR/mtl.!
http://produkte.web.de/go/02/
python grass70.py
   check_shell()
  return split(p)[1]
  if p[1:2] == ':':
Try r41475.
