[GRASS-dev] Write array to (point) attribute table
This must be a very basic question, but I can’t find an easy/direct way to do this. In python, if I have an array with values with a length equal to the number of rows in an attribute table of a (point) vector layer, how can I write those values to a new column in that attribute table. I can of course first create the column, but than how to update that column with the values in the array?
Paulo
On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
This must be a very basic question, but I can't find an easy/direct way to
it should be pretty easy to do with pygrass, unfortunately there is no
example on assigning attributes in the official documentation [1], but it
should be pretty easy, something like that (not tested):
with VectorTopo('myvector', mode='w') as vectormap:
    for feature in vectormap:
        feature.attrs['mycolumn'] = value
Anna
[1]
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#working-with-vector-objects
Paulo
grass-dev mailing list
grass-dev@lists.osgeo.org
On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová <kratochanna@gmail.com>
Thanks, but that seems to write the vector back without attribute table
Anna
[1]
Paulo
On Wed, Sep 30, 2015 at 9:51 AM, Paulo van Breugel
You have to save the changes in the database out from your cycle, with:
vectormap.table.conn.commit()
Pietro
equal to
how can
with the
it
Thanks Pietro. I am, however, not sure I understand (I tried to use it, but
thanks to my limited experience in Python / pygrass not much luck). Just to
be more specific, I am trying to create a script that divides points in
training and test groups, similar to v.kcv, but with points clustered in
space. E.g.,
# Create vector
grass.run_command("v.random", output="testB", npoints=10, overwrite=True)
grass.run_command("v.db.addtable", map="testB", columns="X DOUBLE
PRECISION,Y DOUBLE PRECISION,GR INTEGER")
grass.run_command("v.to.db", map="test", option="coor", columns="X,Y")
# Create groups
vectmap = 'test'
cvals = array(grass.vector_db_select(vectmap, layer = int(1), columns =
'X,Y')['values'].values()).astype(np.float)
centroids,_ = kmeans(cvals,2)
idx,_ = vq(cvals,centroids)
# write results to tabel
Now I would like to write idx to the column 'GR' in the attribute table of
'test'.
p.s. I am first creating the XY columns now, but is there a function to get
the coordinates (cvals) in pygrass directly?
Pietro
    <p.vanbreugel@gmail.com <mailto:p.vanbreugel@gmail.com>> wrote:
    > On Wed, Sep 30, 2015 at 2:02 AM, Anna Petrášová <kratochanna@gmail.com <mailto:kratochanna@gmail.com>>
    > wrote:
    >> On Tue, Sep 29, 2015 at 6:09 PM, Paulo van Breugel
    >> <p.vanbreugel@gmail.com <mailto:p.vanbreugel@gmail.com>> wrote:
    >>> This must be a very basic question, but I can't find an easy/direct way
    >>> to do this. In python, if I have an array with values with a length equal to
    >>> the number of rows in an attribute table of a (point) vector layer, how can
    >>> I write those values to a new column in that attribute table. I can of
    >>> course first create the column, but than how to update that column with the
    >>> values in the array?
    >> it should be pretty easy to do with pygrass, unfortunately there is no
    >> example on assigning attributes in the official documentation [1], but it
    >> should be pretty easy, something like that (not tested):
    >> with VectorTopo('myvector', mode='w') as vectormap:
    >> for feature in vectormap:
    >> feature.attrs['mycolumn'] = value
    > Thanks, but that seems to write the vector back without attribute table
but thanks to my limited experience in Python / pygrass not much luck).
Just to be more specific, I am trying to create a script that divides
points in training and test groups, similar to v.kcv, but with points
clustered in space. E.g.,
# Create vector
# Create groups
vectmap = 'test'
of 'test'.
get the coordinates (cvals) in pygrass directly?
Pygrass has other options, but you can always call v.to.db with the -p flag and read the output directly. See one example at [1].
Moritz
[1] https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.centerline/v.centerline.py#L198
On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
way
equal to
how can
with the
but it
# Create vector
# Create groups
vectmap = 'test'
'test'.
I don't fully understand the example, but yes, you can get coordinates:
        print feature.x
        print feature.y
Pietro
Thanks for the quick response. I basically have a list with values (idx in the example above) which I like to add as a column to the attribute table of an existing vector (point layer). The length of idx is equal to the number of rows in the attribute table. The solution of Anna seems like an elegant solution (and easier and more flexible than other solutions I tried using e.g., sqlite3). However, as I wrote, I end up with a vector without attribute table. You wrote that I “have to save the changes in the database out from your cycle, with: vectormap.table.conn.commit()”. I am, however, not sure what you mean with ‘out from your cycle’ or how to implement that. Great, thanks. I did not find this in the manual. If it is not there, perhaps it would be something worth including? I would not mind providing a text, but I am not sure what would be the best way to do that.
On 30-09-15 16:18, Anna Petrášová wrote:
On Wed, Sep 30, 2015 at 9:27 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
with VectorTopo(‘myvector’, mode=‘w’) as vectormap:
feature.attrs[‘mycolumn’] = value
Thanks Pietro. I am, however, not sure I understand (I tried to use it, but thanks to my limited experience in Python / pygrass not much luck). Just to be more specific, I am trying to create a script that divides points in training and test groups, similar to v.kcv, but with points clustered in space. E.g.,
Create vector
grass.run_command(“v.random”, output=“testB”, npoints=10, overwrite=True)
grass.run_command(“v.db.addtable”, map=“testB”, columns=“X DOUBLE PRECISION,Y DOUBLE PRECISION,GR INTEGER”)
grass.run_command(“v.to.db”, map=“test”, option=“coor”, columns=“X,Y”)
Create groups
vectmap = ‘test’
cvals = array(grass.vector_db_select(vectmap, layer = int(1), columns = ‘X,Y’)[‘values’].values()).astype(np.float)
Now I would like to write idx to the column ‘GR’ in the attribute table of ‘test’.
p.s. I am first creating the XY columns now, but is there a function to get the coordinates (cvals) in pygrass directly?
I don’t fully understand the example,
print feature.x
print feature.y
Pietro
On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
<p.vanbreugel@gmail.com>p.vanbreugel@gmail.com> wrote:
On Wed, Sep 30, 2015 at 11:53 AM, Pietro < <peter.zamb@gmail.com>
way
equal to
how can
of
with the
but it
# Create vector
# Create groups
vectmap = 'test'
of 'test'.
attribute table. You wrote that I "have to save the changes in the database
out from your cycle, with: vectormap.table.conn.commit()". I am, however,
not sure what you mean with 'out from your cycle' or how to implement that.
probably after the for cycle ends you would call this
'vectormap.table.conn.commit()', if it doesn't works, try to put it in the
cycle (I am not sure what is supposed to work).
        print feature.x
        print feature.y
Technically, it's in the manual:
https://grass.osgeo.org/grass70/manuals/libpython/pygrass_vector.html#geometry-classes
but we are lacking more examples of often used constructions. Some other
examples are available in the recent workshop we did:
https://github.com/wenzeslaus/python-grass-addon/blob/master/02_pygrass_library.ipynb
Pietro
I did try both, with no luck so-far. I’ll give it another try though, perhaps I did something else wrong. Thanks, I will have a look at it.
On 30-09-15 17:47, Anna Petrášová wrote:
On Wed, Sep 30, 2015 at 11:20 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Create vector
Create groups
vectmap = ‘test’
probably after the for cycle ends you would call this ‘vectormap.table.conn.commit()’, if it doesn’t works, try to put it in the cycle (I am not sure what is supposed to work).
print feature.x
print feature.y
Technically, it’s in the manual:
but we are lacking more examples of often used constructions. Some other examples are available in the recent workshop we did:
Pietro
Tried out again, but after running the code below, I end up with an empty vector layer (no points and no attribute table). Same if I put the vectormap.table.conn.commit() in the for cycle.
import grass.script as grass
from grass.pygrass.vector import VectorTopo
grass.run_command("v.db.addtable", map="testB", columns="GR INTEGER")
with VectorTopo('testB', mode='w') as vectormap:
        feature.attrs['GR'] = 9
print feature.x
print feature.y
Pietro
Create vector
Create groups
vectmap = ‘test’
            an easy/direct way
            your cycle, with:
        in space. E.g.,
        # Create vector
        overwrite=True)
        DOUBLE PRECISION,Y DOUBLE PRECISION,GR INTEGER")
        columns="X,Y")
        # Create groups
        vectmap = 'test'
        int(1), columns = 'X,Y')['values'].values()).astype(np.float)
        attribute table of 'test'.
    vectormap.table.conn.commit()". I am, however, not sure what you
I did try both, with no luck so-far. I'll give it another try though,
Just a wild guess, here without looking at the library code, but could it be that it should be
VectorTopo('testB', mode='a')
instead of
Moritz
Hi Paulo,
I had the same problem some time ago. I am using pandas for a lot of things and discovered the quickest way to append a column to a vector table is using pandas’ .to_sql dataframe method. Here is my full function for it:
import pandas as pa
dataframe = pa.DataFrame( ... )
def appendColumns(vecttbl,dataframe,join=None,layer=1):
    '''Upload a DataFrame (Series should be first converted into a sql compliant datafram)
    to a grass vector table. Join is a valid column in vecttbl or if None take categories.
    Always joins on df.index, which is not uploaded.'''
    # get sqlite.db info
    db = grass.vector_db(vecttbl)[layer]
    con = sqlite3.connect(db['database'])
    # decide join indeces
    itbl = {False:db['key'],True:join}[join!=None]
    # make series to dataframe
    dataframe.to_sql('pandas_temp',con,if_exists='replace',index_label='ix') # index label?
    # join columns to vecttbl
    grass.run_command('v.db.join',map=vecttbl,column=itbl,
                       other_table='pandas_temp',other_column='ix',
                       subset_columns=','.join(map(str,dataframe.columns)))
    # remove temp table
    cur = con.cursor()
    cur.execute('DROP TABLE IF EXISTS pandas_temp')
    con.commit(); con.close()
    return
The dataframe.to_sql line is essentially all you need, the rest of the function is just prepping.
Hope it helps,
Michel
Create vector
Create groups
vectmap = ‘test’
print feature.x
print feature.y
Pietro
[grass-dev@lists.osgeo.org](mailto:grass-dev@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-dev](http://lists.osgeo.org/mailman/listinfo/grass-dev)
            an easy/direct way
            your cycle, with:
        in space. E.g.,
        # Create vector
        overwrite=True)
        columns="X,Y")
        # Create groups
        vectmap = 'test'
instead of
That is not a valid option; "Mode not supported. Use one of: 'r', 'rw', 'w' ". This did make me try again though, but now with mode='rw', which worked:
idx= array([0, 1, 0, 0, 0, 0, 1, 1, 0, 1])
i = -1
with VectorTopo('testB', mode='rw') as vectormap:
         i = i + 1
         feature.attrs['GR'] = idx[i]
Thanks all for the help/advices
Moritz
Hi Michel,
Thanks! I think I got the suggestions by Anna, Pietro and Moritz working, but this certainly looks like an handy function to have at hand. One possible disadvantage if using this in a script to be shared with others is that it would add an dependency on pandas, wouldn’t it?
Paulo
On 01-10-15 10:01, Michel Wortmann wrote:
Hi Paulo,
import pandas as pa
    # remove temp table
    cur = con.cursor()
    return
Hope it helps,
Michel
Create vector
Create groups
vectmap = ‘test’
print feature.x
print feature.y
Pietro
On Thu, Oct 1, 2015 at 11:28 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
At the and it makes sense. 'w' removes the vectors and starts over. 'rw'
keep the file but ones it for writing. Perhaps 'a' would make better sense
in this case. What the documentation says?
On Thu, Oct 1, 2015 at 10:01 AM, Michel Wortmann
<wortmann@pik-potsdam.de> wrote:
Hi Paulo,
using pandas' .to_sql dataframe method. Here is my full function for it:
To add a ne column on an existing vector map in pygrass: write:
if 'column_name' in vect.table.columns:
    vect.table.columns.drop('column_name')
vect.table.columns.add('column_name', 'column_type')
On it is mentioned that: “”". I think this description is somewhat ambiguous. Especially the mode=‘w’ is unclear to me; I could clearly not write new features to an (existing) vector layer. It might be nice to have a short one-line explanation of each of these options, explaining the difference.
On 01-10-15 17:49, Vaclav Petras wrote:
On Thu, Oct 1, 2015 at 11:28 AM, Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
with VectorTopo(‘testB’, mode=‘rw’) as vectormap:
At the and it makes sense. ‘w’ removes the vectors and starts over. ‘rw’ keep the file but ones it for writing. Perhaps ‘a’ would make better sense in this case. What the documentation says?
The open() method supports a number of option arguments (see the Info documentation for a complete list). In particular, the mode argument can take a a value of r for reading, w for writing, or rw for reading/writing." […] If a vector map is opened with the mode w or rw, then the user can write new features to the dataset
