[GRASS-dev] wrong configure documentation for compilation with wxwidgets ?
Below discussion comes from the DebianGIS mailing list. It raises an issue about documentation of the configure options.
./configure --help shows:
--with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with path, e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)
but this does not seem to work, while below solution does. Looking through the configure file, I don't really understand why this is so (but then again, I can't claim that I understand everything in that file).
So, is the documentation wrong, or does below solution just work by chance ?
Moritz
-------- Original Message --------
Subject: Re: [DebianGIS] testing Debian build of GRASS 6.4 SVN
Date: Tue, 04 Nov 2008 20:13:28 -0600
Organization: Church of Emacs
To: pkg-grass-general@lists.alioth.debian.org
On Tue, 04 Nov 2008 17:16:26 +0100,
Moritz Lennert <mlennert@club.worldonline.be> wrote:
On 05/11/08 03:13, Seb wrote:
Yes, I liked that better too. However, modifying that target as:
,-----[ rules (lines: 66 - 67) ]
| --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
It should be:
--with-wx=/usr/lib/wx/config/gtk2-unicode-release-2.8\
--with-wxwidgets \
Yes, this worked. The packages built fine. The only problem reamining
is the clash betwee grass-preview-doc and grass-doc I posted earlier.
Thanks everyone for your help.
2008/11/5 Moritz Lennert <mlennert@club.worldonline.be>:
It should be:
--with-wxwidgets \
there is no --with-wx just --with-wxwidgets which takes as argument
*path to wx-config* (similary e.g. to --with-gdal)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
On 05/11/08 14:41, Martin Landa wrote:
It should be:
--with-wxwidgets \
But what is weird is that the above combination works, whereas giving the path to wx-widgets doesn't...
still resulted in this at build time:
---<---------------cut here---------------start-------------->---
checking whether to use wxWidgets... yes
checking for wx-config... /usr/bin/wx-config
checking wxWidgets version... 2.6.3
configure: error: *** wxWidgets 2.8.1 or later is required.
make: *** [config-stamp] Error 1
debuild: fatal error at line 1301:
couldn't exec fakeroot debian/rules: ---<---------------cut here---------------end---------------->---
And both for him and for me it works with with-wx.
Moritz
IIUC, configure looks for the string wx-config in the path given to wxwidgets, but as you can see in Debian (when you have several version of wxwidgets installed) you the file might not be called *wx-config*.
>>> It should be:
>>> --with-wxwidgets \
The configure script silently ignores any --with-* options which it
doesn't understand, and it doesn't understand --with-wx.
It's entirely possible that specifying a non-default wx-config script
doesn't work, but that's down the wx installation, not the configure
script.
It should be:
--with-wxwidgets \
script.
Ok, sorry for the noise. I'll see with the OP why my "solution" suddenly made things work for him.
Moritz
