When saving the metadata to pdf the ‘use constraints’ field is not handled correctly. Even when filled in, in the pdf output it shows ‘unknown’ under the use constraints header.
Hi Paulo,
problem with use constraints is fixed in r67340.
Thanks for the report.
Matej
On Tue, Dec 22, 2015 at 6:40 PM Paulo van Breugel <p.vanbreugel@gmail.com> wrote:
Thanks, will try it out
On 23-12-15 15:54, Matej Krejci wrote:
Hi Paulo,
Matej
