[GRASS-dev] wxgrass won't work - how to set up digitization?
Martin,
I just updated all and now wxgrass won’t start. I get the following error…
GRASS 6.3.cvs (spearfish60_test):~ > Traceback (most recent call last):
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py”, line 57, in
import gui_modules.wxgui_utils as wxgui_utils
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/wxgui_utils.py”, line 36, in
import mapdisp
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/mapdisp.py”, line 55, in
import toolbars
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/toolbars.py”, line 28, in
from digit import Digit as Digit
File “/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/digit.py”, line 60, in
from grass6_wxdriver import DisplayDriver
ImportError: No module named grass6_wxdriver
I assume that I need the new displaydriver C module you have written. I copied it into my running version and tried to make it, but got the following error…
Last login: Sat Aug 18 11:48:21 on ttyp1
Welcome to Darwin!
cmb-MBP:~ cmbarton$ cd /Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/display_driver/
cmb-MBP:/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/display_driver cmbarton$ make
Makefile:17: warning: overriding commands for target clean' ../../../include/Make/Rules.make:34: warning: ignoring old commands for target clean’
cat ./driver.i > grass6_wxdriver.i
echo “/* auto-generate swig typedef file (with some GRASS functions removed) */” >> grass6_wxdriver.i
cat ./driver.h >> grass6_wxdriver.i
swig -c++ -python -shadow grass6_wxdriver.i
make: swig: Command not found
make: *** [grass6_wxdriver_wrap.cxx] Error 127
What do I need to do to make this work?
BTW, my GRASS is compiled with PYTHON support, so swig ought to be there. I probably am just doing this wrong.
Thanks
Michael
Director of Graduate Studies
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
Hi Michael,
now fixed in SVN. The C++ driver is not finished yet.
Martin
2007/8/19, Michael Barton <michael.barton@asu.edu>:
Martin,
I just updated all and now wxgrass won't start. I get the following
error...
   File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/wxgui.py",
line 57, in <module>
   File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/wxgui_utils.py",
line 36, in <module>
     import mapdisp
   File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/mapdisp.py",
line 55, in <module>
     import toolbars
   File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/toolbars.py",
line 28, in <module>
   File
"/Applications/Grass/GRASS-6.3.app/Contents/Resources/etc/wx/gui_modules/digit.py",
line 60, in <module>
following error...
Welcome to Darwin!
cmbarton$ make
Makefile:17: warning: overriding commands for target `clean'
echo "/* auto-generate swig typedef file (with some GRASS functions
removed) */" >> grass6_wxdriver.i
BTW, my GRASS is compiled with PYTHON support, so swig *ought* to be there.
Thanks
Michael
phone: 480-965-6213
fax: 480-965-7671
Martin Landa <landa.martin@gmail.com> * http://gama.fsv.cvut.cz/~landa *
On 20/08/07 12:45, Martin Landa wrote:
Hi Michael,
Does this mean we will have mission-critical elements (such as digitiation) in C++ ? In view of all the problems this has caused in the past, I would strongly plead against this.
Moritz
For reasons which I've gone over more times that I care to remember, I
strongly suggest that anything which links against GRASS libraries
should be a separate program.
Sounds like an item for a developer FAQ or maybe it should be a FMC
(frequently made comment) :wink:
Jerry
-----Original Message-----
From: grass-dev-bounces@grass.itc.it [mailto:grass-dev-bounces@grass.itc.it]
On Behalf Of Glynn Clements
Sent: Monday, August 20, 2007 3:30 PM
To: Moritz Lennert
Cc: Martin Landa; grass-gui; Michael Barton; GRASS developers list
Subject: Re: [GRASS-dev] Re: [GRASSGUI] Re: wxgrass won't work - how to set
updigitization?
grass-dev mailing list
grass-dev@grass.itc.it
2007/8/20, Moritz Lennert <mlennert@club.worldonline.be>:
in C++ is written only minimalistic display driver (library) for
digitization tool which draws vector elements on map canvas. This
library is used only for rendering purposes (question of speed). C++
because wxWidgets is written in C++! It shouldn't case any problems.
I am not sure what you refer to (r.terraflow pain is more connected
with the way how this module is written AFAIK).
Martin
Moritz
Do you mean the actual rendering, or retrieving the vector data to be
rendered?
C++
Some of r.terraflow's problems are due to extensive use of C++
features (e.g. templates, STL). But even with minimal use of C++, you
still tend to end up with relatively fragile binaries (i.e. they won't
work on a system that's even slightly different to the one on which
they were compiled).
But my main concern is about calling GRASS library functions directly
from the GUI, whether via C or C++. As I've mentioned before, the
GRASS API is unsuitable for such use.
2007/8/22, Glynn Clements <glynn@gclements.plus.com>:
rendered?
Sorry, I mean retrieving the vector data to be rendered...
Regards, Martin
> rendered?
That probably does need to be done in C.
You could use a slave process to do that part, but it would need to be
persistent; you can't spawn a new command for each operation.
If the Python code is loading a binary module which uses the GRASS
libraries, the digitiser needs to be a separate process from the rest
of wxgrass.
