In the wxGUI digitizer, I can no longer select vector features. Since
I can not select vector features, I can't do anything, no move,
delete, edit, etc.
Unfortunately this applies to all branches.
Markus M
delete, edit, etc.
Markus M
Hello Markus,
here on a fresh 6.4 svn build (59140) it works.
Did you check if your vector map is 3d ?
For the same reason I've never been able to edit features with non-null
elevation in wxGUI digitizer.
Yours,
Vincent.
delete, edit, etc.Unfortunately this applies to all branches.
Markus M
grass-dev mailing list
grass-dev@lists.osgeo.org
On Tue, Feb 25, 2014 at 10:31 PM, Vincent Bain <bain@toraval.fr> wrote:
Hello Markus,
here on a fresh 6.4 svn build (59140) it works.Did you check if your vector map is 3d ?
Thanks! That was it!
Yours,
Markus M
2014-02-25 22:52 GMT+01:00 Markus Metz <markus.metz.giswork@gmail.com>:
elevation in wxGUI digitizer.Thanks! That was it!
I will take a look on this issue, Martin
Thank you Martin, it would be nice to fix it. Sorry for my laziness, the
issue was known for quite a long time, but I did not insist, doing the
job with tcltk v.digit :
http://lists.osgeo.org/pipermail/grass-user/2013-April/067765.html
Bye,
Vincent.
