Hi guys,
I’m using trunk, updated to rev 73962 today. Grass built and compiled with no errors, but I get this error on startup (not worried about the missing locations):
Starting GRASS GIS…
ERROR: Location <UNB_Lambert_Conformal> not found
ERROR: Mapset <Baffin_Bay> not found
File “/usr/local/grass-7.7.svn/gui/wxpython/gis_set.py”, line 1163, in
GRASSStartUp = StartUp(0)
File “/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py”, line 8628, in init
self._BootstrapApp()
File “/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_core.py”, line 8196, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “/usr/local/grass-7.7.svn/gui/wxpython/gis_set.py”, line 1151, in OnInit
StartUp = GRASSStartup()
File “/usr/local/grass-7.7.svn/gui/wxpython/gis_set.py”, line 226, in init
self._set_properties(grassVersion, grassRevisionStr)
File “/usr/local/grass-7.7.svn/gui/wxpython/gis_set.py”, line 322, in _set_properties
self.lbmapsets.SetSelection(0, force=True)
File “/usr/local/grass-7.7.svn/gui/wxpython/gis_set.py”, line 1137, in SetSelection
wx.LIST_STATE_SELECTED)
File “/usr/lib/python2.7/dist-packages/wx-3.0-gtk3/wx/_controls.py”, line 4529, in SetItemState
return controls.ListCtrl_SetItemState(*args, **kwargs)
wx._core.PyAssertionError: C++ assertion “litem >= 0 && (size_t)litem < GetItemCount()” failed at …/src/generic/listctrl.cpp(3422) in SetItemState(): invalid list ctrl item index in SetItem
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use ‘–help’ for further options
grass77 --help
See also: https://grass.osgeo.org/grass77/manuals/helptext.html
Exiting…
Any ideas what is happening?
~ Eric Patton
