[GRASS-dev] wxGUI in GRASS 6.4.1
From: Michael Barton <Michael.Barton@asu.edu<mailto:Michael.Barton@asu.edu>>
Date: October 14, 2010 6:57:37 PM MST
To: Martin Landa <landa.martin@gmail.com<mailto:landa.martin@gmail.com>>
Subject: Re: [GRASS-dev] wxGUI in GRASS 6.4.1
I do the same thing, but nothing happens. No error, no messages about compiling. Nothing. I've only tried this in 6.5 so far.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Oct 14, 2010, at 2:09 PM, Martin Landa wrote:
2010/10/14 Michael Barton <Michael.Barton@asu.edu<mailto:Michael.Barton@asu.edu>>:
I tried that and exactly nothing happened. (GRASS 6.5)
nothing?
For me
cd gui/wxpython/vdigit
make
works. BTW, install issue fixed in r43922.
martin
Martin Landa <landa.martin gmail.com<http://gmail.com>> * Studijní program Geodézie a kartografie – GeoWikiCZ
As you are using 6.5 here and not 6.4.1, nothing happens probably
because vdigit has been successfully compiled already (it is disabled
only in 6.4).
Have you seen in 6.5 any error messages in the wxGUI command console
after startup that make you think that vdigit is not available, or is
there no Digitize option in the map display?
Markus M
Michael
C. Michael Barton
nothing?
For me
make
martin
Martin Landa <landa.martin gmail.com<http://gmail.com>> * http://geo.fsv.cvut.cz/~landa
grass-dev mailing list
grass-dev@lists.osgeo.org
It is not present in 6.5 and I get the following message in the command console:
Vector digitizer not available
Reason: dlopen(/Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc/wxpython/vdigit/_grass6_wxvdigit.so, 2): Library not loaded: /usr/local/lib/wxPython-unicode-2.8.11.0/lib/libwx_macud-2.8.0.dylib
  Referenced from: /Applications/Grass/GRASS-6.5.app/Contents/MacOS/etc/wxpython/vdigit/_grass6_wxvdigit.so
  Reason: Incompatible library version: _grass6_wxvdigit.so requires version 8.0.0 or later, but libwx_macud-2.8.0.dylib provides version 7.0.0
Note that the wxGUI's vector digitizer is currently disabled
(hopefully this will be fixed soon). Please keep an eye out
for updated versions of GRASS. In the meantime you can use
"v.digit" from the Develop Vector menu.
Michael
C. Michael Barton
only in 6.4).
Markus M
Michael
C. Michael Barton
nothing?
For me
make
martin
grass-dev Info Page
