[GRASS-dev] wxgui_items.xml: outdated
I have realized that gui/wxpython/xml/wxgui_items.xml is not properly
updated with the current module descriptions.
This is an issue since we get duplication of almost identical strings
which then drive mad our translators.
It is really a job for
gui/wxpython/tools/update_menudata.py
but this scripts seems to be also outdated while looking to be the
perfect solution.
Anyone willing to fix this:
GRASS 7.1.svn (nc_spm_08_grass7):~/software/grass71/gui/wxpython >
python tools/update_menudata.py -d
Step 1: running make...
Step 2: parsing modules...
Step 3: reading menu data...
Step 4: updating menu data...
  File "tools/update_menudata.py", line 176, in <module>
    sys.exit(main())
  File "tools/update_menudata.py", line 156, in main
    updateData(data, modules)
  File "tools/update_menudata.py", line 74, in updateData
    for node in data.tree.getiterator():
AttributeError: LayerManagerMenuData instance has no attribute 'tree'
thanks
Hi Markus.
On Sat, Oct 31, 2015 at 9:41 AM, Markus Neteler <neteler@osgeo.org> wrote:
Do you mean description elements in wxgui_items.xml? Or do you mean other XMLs as well?
In general, the label element in both wxgui_items.xml and toolboxes.xml is a menu-specific string which is supposed to be very short (1-3 words) and mostly in a form of command, possibly ending with three dots. There is nothing like this in modules, although it would be a good idea to have it there. (Note that label and description elements in the menus are something else than label and description in modules; this should be fixed as well.)
The description element in toolboxes.xml is taken from label and description. In wxgui_items.xml, content element and description element is unique to this file, although there might be some overlaps. Is this what you mean? Do you have some examples?
Here is some documentation:
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/docs/wxgui_sphinx/src/wxgui_toolboxes.rst#L200
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/xml/toolboxes.dtd
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/xml/wxgui_items.dtd
perfect solution.
I looks like there is no use for this script now. What I know is in the doc which says that “Historically, menudata.xml file was in the source codes and was partially maintained by the script gui/wxpython/tools/update_menudata.py which updated the description and keywords (based on module’s label or description, and keywords).”
I’m not sure if I was ever able to run the original workflow successfully (before introducing the toolboxes) which is partially the reason why the README still mentions update_metadata.py.
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/docs/wxgui_sphinx/src/wxgui_toolboxes.rst#L230
https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/README#L64
The main point is that all updates now happen automatically, so there is no need for manual patching of menudata.xml or any other file as it was in the past.
The issue which the new system inherited from the old one is that the description element in GUI XMLs is a combination of label and description from a module’s interface description as the documentation linked above says. I always wondered why this doesn’t bother translators, but since I don’t understand the translation process, I choose to preserve the current system which was there for quite some time already (perhaps from the beginning of wxGUI). Is this what you are referring to? Example would be helpful here as well. If this is the issue, what would be the preferred solution considering that the strings are used in GUI for description in Layer Manager status bar but also for search in Search modules tab?
Vaclav
Step 1: running make…
Step 2: parsing modules…
Step 3: reading menu data…
Step 4: updating menu data…
File “tools/update_menudata.py”, line 176, in
sys.exit(main())
File “tools/update_menudata.py”, line 156, in main
File “tools/update_menudata.py”, line 74, in updateData
AttributeError: LayerManagerMenuData instance has no attribute ‘tree’
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
XMLs as well?
For now I mean wxgui_items.xml. Since I am not familiar with the
mechanism I didn't check the rest.
Yeah, it is a bit confusing.
For an example, see
https://trac.osgeo.org/grass/changeset/66687
This subtle "tuning" of strings is not a good idea.
grep "label\|description" wxgui_items.xml | wc -l
116
of almost identical strings. Almost means not identical which means
that all of them have to be translated again. Rather a PITA for the
translators.
I started to read the README but it is rather short :slight_smile:
perfect solution.
which says that "Historically, menudata.xml file was in the source codes and
``gui/wxpython/tools/update_menudata.py`` which updated the description and
keywords (based on module's label or description, and keywords)."
I'm not sure if I was ever able to run the original workflow successfully
OK, it would be good to clean that up.
Indeed not completely since xml/wxgui_items.xml appears to be manually
written (or outdated and based on older description lines?)
so there is no
past.
... yes, which is good.
from a module's interface description as the documentation linked above
says. I always wondered why this doesn't bother translators,
It does.
but since I don't understand the translation process,
In which sense? You take a po file and translate... a very lengthy
job. And almost identical strings have to be translated several times
which does not encourage anyone.
It would be great to have a script which autoextracts the strings for
gui/wxpython/xml/wxgui_items.xml as "dry" run (similar to how the old
tools/update_menudata.py worked) in order to decide on a case by case
base when to abbreviate or when not. Again, r66687 is an example where
I reinstated the actual wording, a perfect computer job.
Hope you see now what I mean,
XMLs as well?
mechanism I didn’t check the rest.
Thinking more about it I don’t think the main issue is related to wxgui_items.xml, please see below.
For an example, see
This subtle “tuning” of strings is not a good idea.
grep “label|description” wxgui_items.xml | wc -l
116
translators.
I don’t think there is 116 duplicated strings in wxgui_items.xml. The label element text is unique for XML files (see the “bit confusing” part). This cuts the number to half. Than there are wxGUI-only items such as New (OnWorkspaceNew) which have the string only here (approx 10 items). Than there are items with command element which is an actual command, so executable and parameters. These, in theory, have different description than the module itself, e.g. “g.manual -i” and “g.manual entry=wxGUI”.
Finally, there are items with related-module element where there is some module for it, but the GUI starts a specialized wrapper instead or it is a g.gui module and the GUI starts integrated into the main one as opposed to starting a separate process. CommonFormatsImport (r.in.gdal) is an example of the former and GraphicalModeler (g.gui.gmodeler) of the latter.
All (or most) of these entries have keywords which are definitively duplicated and description which may or may not overlap with description from the module. For example, the g.gui.gmodeler labels says “Graphical Modeler” and description “Allows interactively creating, editing and managing models” while GraphicalModeler description says “Launch Graphical modeler”. For CommonFormatsImport and r.in.gdal the overlap is there.
Even if all items with command element and all items with releated-module element had description element which content overlaps with module’s description and/or label, it would be only 29 strings. The actual current number of string which are/should be the same is probably under 20. It would be ideal if it would be 0, but do you think this is what translators complain about?
wxgui_toolboxes.rst should be exhaustive documentation of the toolbox mechanism but regarding the translations, it is just using whatever was there before.
perfect solution.
This is how it was designed. When it is something which is a module, it is in toolboxes.xml which are combined with generated module_item.xml. If it is some GUI thing (i.e. not the automatically generated GUI dialog), it is specified fully manually in wxgui_item.xml. The 29 cases mentioned above might be something in between which in the current design fall back to the GUI items category, thus manually managed. Design can be changed. Question is how.
so there is no
past.
… yes, which is good.
says.
Comparing to the max 29 strings above, this happen for every module with both label and description. Not all modules have it but if yes, it would be approx 530 strings in case my guess about how translation works* is right. It seemed to me so significant that I though I’m wrong about how it works because somebody would complain about that.
(*) What I think is that label+description are combined and put to the XML, then this string is extracted later from one of the generated XMLs and put to some file and extracted to po files. On runtime, somehow the strings from XML are linked to the translated ones.
It does.
There is apparently a lot of people bothered with many other things but they are silent, but this is a discussion for some other time.
In which sense? You take a po file and translate… a very lengthy
This I understand. The part I don’t understand is how strings from XML and other parts appear in the po files (it is in the Makefiles and Python scrips, I don’t know if there is some doc for that).
gui/wxpython/xml/wxgui_items.xml as “dry” run (similar to how the old
As the old system, this would depend on people running it. We must have something
Yes, but now I want to know if the normal module entries in menu (for modules with both label and description) are the issue or not since if they are, it is far more significant.
