for some weeks the wxGUI no longer shows the box when zooming...
Should I open a ticket for that?
thank
thank
On Wed, Dec 31, 2014 at 9:31 AM, Markus Neteler <neteler@osgeo.org> wrote:
Trunk or release branch? When I zoom I can see the red line. Does it happen
with a fresh GUI instance?
Anna
thank
grass-dev mailing list
grass-dev@lists.osgeo.org
On Fri, Jan 2, 2015 at 2:05 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
Should I open a ticket for that?Trunk or release branch? When I zoom I can see the red line. Does it happen
Yes. Confirmed in trunk
GRASS version: 7.1.svn
GRASS SVN Revision: 63931
Build Date: 2015-01-02
Build Platform: x86_64-unknown-linux-gnu
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.4
Python: 2.7.5
wxPython: 2.8.12.0
Platform: Linux-3.17.3-200.fc20.x86_64-x86_64-with-fedora-20-Heisenbug
In the release branch it works fine.
wrote:
>> Hi,
happen
> with a fresh GUI instance?Yes. Confirmed in trunk
GDAL/OGR: 1.10.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.8.7.4
Python: 2.7.5
wxPython: 2.8.12.0
Platform: Linux-3.17.3-200.fc20.x86_64-x86_64-with-fedora-20-HeisenbugIn the release branch it works fine.
Let me know if r63937 works, otherwise wxPython 3 seems to solve it as
well, but not many people are using it yet.
For some reason the device context (which enables drawing with
transparency) refuses to draw the lines with certain style. On my machine I
get solid line, although it is supposed to be dashed line. On your machine
it refuses to draw at all I guess.
Anna
On Sat, Jan 3, 2015 at 4:41 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
>> Hi,
It does, thanks a lot!
otherwise wxPython 3 seems to solve it as well,
but not many people are using it yet.For some reason the device context (which enables drawing with transparency)
refuses to draw the lines with certain style. On my machine I get solid
line, although it is supposed to be dashed line. On your machine it refuses
Before yes, now it draws again the dashed line as expected.
