[GRASS-dev] wxGUI on mac
Massimo,
Sounds like you cannot use my binaries and that you are compiling yourself.
William learned sometime back that wxPython for Mac ver. 2.8 needs to run 32 bit and adapted the GRASS Mac make system to do that. It works great on Snow Leopard using the system Python 2.6.1 and current stable wxPython.For other versions there is no guarantee and we have not coded this to work on wxPython > 2.8 or Python > 2.6. It may work or it may not. It will be good to see how to get GRASS to compile with the new Python 2.7 and wxPython 2.9. FWIW, it also does not run on the newest builds of TclTk.
William has been working on getting GRASS to compile and run on the newest wxPython without success yet. I do not yet have Lion, but probably will on at least one machine before the end of the year. William recently noted that there may be some code changes to wxPython 2.9 that cause GRASS to crash. I haven't yet been able to look into these.
If you'd like to help on this, it would be certainly appreciated.
Michael
______________________________
C. Michael Barton
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
    http://www.public.asu.edu/~cmbarton
On Sep 1, 2011, at 12:25 AM, grass-dev-request@lists.osgeo.org wrote:
Date: Wed, 31 Aug 2011 22:35:44 +0200
From: Massimo Di Stefano <massimodisasha@gmail.com>
Subject: Re: [GRASS-dev] wxGUI on mac
To: Helena Mitasova <hmitaso@ncsu.edu>
Cc: GRASS-dev list <grass-dev@lists.osgeo.org>
Message-ID: <D2750221-F82B-45E4-91DA-4AB98DA11BEA@gmail.com>
Content-Type: text/plain; charset=us-ascii
Hi All,
I'm on lion too,
but before lion my problem with wx and snow leopard was that i'm using python 64 bit (and wx is not ready yet)
The last time i tried to update my wx to 2.9.x to be able to have all running as 64bit i had lot of problems
so i switched to the old tcltk gui for a stable usage.
i'll provide as soon as possible all the issue i'm having running wxpython (using python.org) in 64 bit mode
on both snow leopard and lion.
--Massimo.
