i’m compiling grass from svn source using the 6.5 version,
i’m on a debian sid derived distro “sidux”
i used this configure to build grass :
CFLAGS=“-ggdb -Wall -Werror-implicit-function-declaration” ./configure --with-tcltk-includes=/usr/include/tcl8.5/
–with-freetype --with-freetype-includes=/usr/include/freetype2/ --with-cxx --enable-64bit --with-geos --with-ffmpeg
–with-mysql --with-postgres --with-postgres-includes=/usr/include/postgresql/ --with-mysql-includes=/usr/include/mysql/
–with-ffmpeg-includes=/usr/include/ffmpeg/ --with-odbc --with-python --with-sqlite --with-wxwidgets=/usr/bin/wx-config
–with-readline --enable-largefile --with-proj-share=/usr/share/proj --with-cairo --with-motif
wx-config --version-full
give me :
2.8.7.1
i used :
g.gisenv set=“DEBUG=5”
Tring to tun the wxgui it starts without errors, but try to add a raster map in the canvas, i'm not able to display it
zoom to selected map do nothing, and the coordinates under the mouse movment are not displayer
in the output window i can see this log details :
1. ```
1. ```
File "/usr/local/grass-6.5.svn/etc/wxpython/gui_modules/ma
1. ```
pdisp_window.py", line 450, in OnPaint
1. ```
1. ```
self.pdc.DrawToDCClipped(dc, rgn)
1. ```
File "/usr/local/grass-6.5.svn/etc/wxpython/vdigit/grass6_
1. ```
wxvdigit.py", line 393, in DrawToDCClipped
1. ```
1. ```
def DrawToDCClipped(self, *args): return
1. ```
_grass6_wxvdigit.PseudoDC_DrawToDCClipped(self, *args)
1. ```
TypeError
1. ```
1. ```
in method 'PseudoDC_DrawToDCClipped', argument 2 of type
1. ```
'void *'
1. ```
1. ```
1. ```
pdisp_window.py", line 542, in OnIdle
1. ```
1. ```
self.UpdateMap(render=True)
1. ```
1. ```
pdisp_window.py", line 667, in UpdateMap
1. ```
1. ```
self.Draw(self.pdc, self.img, drawid=id)
1. ```
1. ```
pdisp_window.py", line 271, in Draw
1. ```
1. ```
pdc.SetBackground(bg)
1. ```
1. ```
wxvdigit.py", line 384, in SetBackground
1. ```
1. ```
def SetBackground(self, *args): return
1. ```
_grass6_wxvdigit.PseudoDC_SetBackground(self, *args)
1. ```
TypeError
1. ```
1. ```
in method 'PseudoDC_SetBackground', argument 2 of type
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
pdisp_window.py", line 2510, in OnZoomToMap
1. ```
1. ```
self.ZoomToMap()
1. ```
1. ```
pdisp_window.py", line 2561, in ZoomToMap
1. ```
1. ```
self.UpdateMap()
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
self.ZoomToMap()
1. ```
1. ```
1. ```
1. ```
self.UpdateMap()
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
pdisp_window.py", line 1017, in MouseActions
1. ```
1. ```
self.OnLeftUp(event)
1. ```
1. ```
pdisp_window.py", line 1809, in OnLeftUp
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
pdisp.py", line 628, in OnRender
1. ```
1. ```
self.MapWindow.UpdateMap(render=True)
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
1. ```
TypeError
1. ```
1. ```
1. ```
'wxBrush const &'
i also tried to run g.gui wxpython using "strace", i had :
1. ```
strace g.gui wxpython
1. ```
execve("/usr/local/grass-6.5.svn/bin/g.gui", ["g.gui", "wxpython"], [/* 48 vars */]) = 0
1. ```
brk(0) = 0x10e5000
1. ```
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fbb6b49b000
1. ```
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
1. ```
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fbb6b499000
1. ```
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
1. ```
open("/usr/local/grass-6.5.svn/lib/tls/x86_64/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
1. ```
stat("/usr/local/grass-6.5.svn/lib/tls/x86_64", 0x7fff6647d510) = -1 ENOENT (No such file or directory)
1. ```
open("/usr/local/grass-6.5.svn/lib/tls/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
1. ```
stat("/usr/local/grass-6.5.svn/lib/tls", 0x7fff6647d510) = -1 ENOENT (No such file or directory)
1. ```
open("/usr/local/grass-6.5.svn/lib/x86_64/libgrass_gis.so", O_RDONLY) = -1 ENOENT (No such file or directory)
1. ```
stat("/usr/local/grass-6.5.svn/lib/x86_64", 0x7fff6647d510) = -1 ENOENT (No such file or directory)
I have no clue on how to debug this weird situation, a friend on grass irc using the same wxpython version on the same grass revision on ubuntu (i suppose) X86_64
has not problems to run the wxpython gui.
i enabled the debug symbols but i need to learn how to use gdb on the g.gui executable.
Any suggestion can make me happy!
thanks to All,
Massimo.
(P.S.: apologize me if this mail is sended twice)
