[GRASS-dev] ** (wxgui.py:19192): WARNING **: invalid source position for vertical gradient
just a fresh compiled
GRASS version: 7.3.svn
GRASS SVN revision: r71243
Build date: 2017-07-08
Build platform: x86_64-pc-linux-gnu
GDAL: 2.2.0
PROJ.4: 4.9.3
GEOS: 3.5.1
SQLite: 3.16.2
Python: 2.7.13
wxPython: 3.0.2.0
Platform: Linux-4.9.0-3-amd64-x86_64-with-debian-9.0
I get following messages during GUI startup
GRASS 7.3.svn
(nc_spm_08_grass7):~/dev/cpp/grass7_trunk/bin.x86_64-pc-linux-gnu >
gradient
gradient
gradient
gradient
any idea? or just ignoring?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wxgui-py-19192-WARNING-invalid-source-position-for-vertical-gradient-tp5327115.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
Hi Helmut,
don't know if you finally found the reason of the warning message you
mentioned back in july. On a freshly built Debian stretch virtual
machine I have the same issue today :
** (wxgui.py:5023): WARNING **: invalid source position for vertical
gradient
I guess it is not a fatal issue as GRASS seems to work nicely despite
this error.
Best,
Vincent.
GDAL: 2.2.0
PROJ.4: 4.9.3
GEOS: 3.5.1
SQLite: 3.16.2
Python: 2.7.13
wxPython: 3.0.2.0
GRASS 7.3.svn
gradient
gradient
gradient
gradient
best regards
Helmut
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Wed, Sep 20, 2017 at 9:06 AM, Vincent Bain <bain@toraval.fr> wrote:
Hi Helmut,
gradient
this error.
Searching the error in internet I found a similar one:
** (thunar:2530): WARNING **: invalid source position for vertical gradient
https://github.com/lassekongo83/zuki-themes/issues/104
Fix:
https://github.com/lassekongo83/zuki-themes/commit/318efd3a83f6305414f58b9dca417072c16e5ef6
Maybe something like this could be applied also here?
Thank you Markus for your suggestion,
unfortunately I don't have any idea where to find the relevant piece of
code implied.
Vincent.
> Hi Helmut,
> gradient
> this error.
Fix:
You would need to isolate which part of the GUI is responsible for it, otherwise there is too many options to guess. If this started recently, maybe you can isolate the commit, that would help too.
Anna
unfortunately I don’t have any idea where to find the relevant piece of
code implied.
Vincent.
Hi Helmut,
don’t know if you finally found the reason of the warning message you
gradient
this error.
Fix:
Thank you Anna for your reply,
the messages pops up in the terminal when I interact with the layer
manager window like : swithching between thumbnail, resizing window,
confirming deletion of a map).
after digging it a little bit deeper, I guess it has rather something to
do with the environment : I currently work on different debian machines;
the issue happens when I build the latest trunk version (r:71500) on a
new/clean debian 9 (stretch). Building the same release on my old debian
8 works fine.
I have several concurrent python versions on my old machine I switch
with update-alternative, but I am not sure about which version GRASS is
built against on each machine...
Vincent.
Anna
        piece of
        code implied.
        Vincent.
        écrit :
        > On Wed, Sep 20, 2017 at 9:06 AM, Vincent Bain
        > > Hi Helmut,
        > > don't know if you finally found the reason of the warning
        message you
        > > mentioned back in july. On a freshly built Debian stretch
        virtual
        > > machine I have the same issue today :
        > > ** (wxgui.py:5023): WARNING **: invalid source position
        for vertical
        > > gradient
        > > I guess it is not a fatal issue as GRASS seems to work
        nicely despite
        > > this error.
        > Searching the error in internet I found a similar one:
        > ** (thunar:2530): WARNING **: invalid source position for
        vertical gradient
        > https://github.com/lassekongo83/zuki-themes/issues/104
        > Fix:
        > Maybe something like this could be applied also here?
        > Markus
8 works fine.
Please check the wxPython version, through g.gui > Help > About system
wxPython: 3.0.2.0
My old debian 8.8 install has wxPython: 3.0.1.1
On another hand, trying to find out what was new between debian 9.0 and
debian 8.8 configurations, I noticed there was a difference concerning
wx-config alternatives:
        - in the former it pointed towards
        /usr/lib/i386-linux-gnu/wx/config/base-unicode-3.0
        - while in the newer it points toward
        /usr/lib/i386-linux-gnu/wx/config/gtk2-unicode-3.0
I tried to rebuild (after a distclean) with the previous configuration,
i.e. base-unicode-3.0
        $ update-alternatives --config wx-config
but the error still rises.
Perhaps I should try to revert to wxPython 3.0.1.1
Vincent.
> 8 works fine.
looks like this problem appeared some time ago :
https://lists.osgeo.org/pipermail/grass-user/2016-August/074641.html
As Robert asked, is there a way to set, at least temporarily, the
verbosity of these messages ?
V.
Le mercredi 20 septembre 2017 à 15:44 +0200, Vincent Bain a écrit :
wxPython: 3.0.2.0
Vincent.
> > 8 works fine.
> Markus
not easily I think, maybe if you recompile some of the underlying
libraries and set somehow their verbosity, it would be theoretically
possible, but I didn't investigate that option.
V.
wxPython: 3.0.2.0
Vincent.
> > 8 works fine.
> Markus
Well,
thanks Anna and Markus for you interest.
It might not be specifically a GRASS issue. Changing the gtk+ theme
engine of my desktop from Adwaita to Clearlooks solved the problem in
one go, no more warnings... did not look attentively but it seems
adwaita was the only problematic theme (I mean among those installed
down here).
Hope this instant of serendipity can help you find a cure to this buggy
behavior !
Yours,
Vincent.
> V.
>> wxPython: 3.0.2.0
>> Vincent.
>> > > 8 works fine.
>> > Markus
>> _______________________________________________
